5508 WLC - need MIB/OIDs for CPU utilization, other things
Hi;
We are finally installing 5508 controllers at multiple sites.  (Yaaaay) We have an existing SNMP mangement system (Zenoss) that will work fine with these 5508's if I can figure out which OIDs report things like CPU utilization, free mem, temp, number of clients etc.  We already have modeler plugins that list the number of APs managed and will also show the wired interface  stats.
Attached are two files with the resutls of snmpwalk. One has the raw OIDs, the other has the OIDs with the symbolic prefixes.  Please take a moment to look at those files.
Most of that I'm looking for seems to be missing. For example, in other Cisco forum posts, it was mentioned that CPU utilization was available via this OID:
agentCurrentCPUUtilization ......OID: 1.3.6.1.4.1.14179.1.1.5.1
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.14179.1.1.5.1
and, Free Mem was available here:
agentFreeMemory      free RAM of in Kbytes ....OID: 1.3.6.1.4.1.14179.1.1.5.3
Problem is, none of those OIDs are returned when I walk the 5508. For example:
[ZenStatus]$ snmpwalk -Ofn -v2c -c M31eRt4 10.254.248.3 | grep -F "1.3.6.1.4.1.14179"
[ZenStatus]$
(nothing even close to the agentCurrentCPUUtilization OID is  found)
We are currently running  7.0.235.0 .
I'm pretty baffled at this point.  I've spent hours poring over the output of the walks and can't find any of the OIDs that are mentioned on the 'net as having the info I'm looking for.
Steve
Everyone's tags (6)
Re: 5508 WLC - need MIB/OIDs for CPU utilization, other things
(Note: I just noticed that I failed to attached the file with the raw numeric OIDs in my original post.  I have attached it here)
Thanks Saravanan, but I've tried all the obvious stuff. There are plenty of MIBs listed by Cisco that contain OIDs for various things, but the bottom line is this: Our 5508's are only making available those OIDs that I listed in the two files in the original message. The existence of various OIDs on the Cisco site that are in various MIBs don't do me any good if the 5508, when walked, does not respond with them. So, I need to know one of two things:
* in the OIDs that I see when I walk it now, are any of those CPU, Free Mem, concurrent Clients or other great stuff?
* If not, then how do I modify the 5508 (NOT the management console - it just blindly walks the 5508) so that the 5508 DOES output the info we need?
FYI:  From the link you sent,
ObjectcseSysCPUUtilization
OID1.3.6.1.4.1.9.9.305.1.1.1
snmpwalk -Ofn -v2c -c M31eRt4 10.254.248.3 | grep -F "1.3.6.1.4.1.9.9"   resulted in no hits. (This can also be verified by opening the attached
5508-snmpwalk-numeric.txt file and searching for that OID)
Steve
Steve, did you make any
Steve, did you make any progress on SNMP OIDs with WLCs?
I am having similar situation where walk does not respond to MIBs. Case with TAC is not going anywhere.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=ciscoLwappRogueMIB#oidContent
MIB: CISCO-LWAPP-ROGUE-MIB
ciscoLwappRogueMIB - 1.3.6.1.4.1.9.9.610
Thanks!
Prasanna
I can also see something related to CPU:
ciscoLwappSysMIBObjects
1.3.6.1.4.1.9.9.618.1
which I don't think work with you snmpwalk as well, right?
I am not sure why this is happening, but have you tried to change the SNMP version and test? I remember ther was once some closer issue was related to SNMP versoin. not sure though.
Thanks.
Amjad
Rating useful replies is more useful than saying "Thank you"
The MIBs should be fine , we need to run debug snmp all on the WLC while trying to pull the value of the OIDs mentioned above.
Thanks everyone, I think we are getting closer. Debug was a good tip!
When I did the SNMP walks with debug on, in the first instance, (cseSysCPUUtilization 1.3.6.1.4.1.9.9.305.1.1.1 ), it seemed to recognize what it was looking for, but never returned a value. The 'Searching for next instance" never returns anything useful.
This makes me think that perhaps something is wrong with the 5508 ... we are trying to upgrade it to 7.2, but let's not give up on 7.0 yet, please.
In the second instance, (ciscoLwappSysMIBObjects 1.3.6.1.4.1.9.9.618.1), it finds plenty of OIDs. Perhaps some of them are what we need, the problem is figuring out which numeric OID value corresponds to things like CPU, client count, free mem.
Details:
Tried the following walk:
[zenoss]$ snmpwalk -On -v2c -c asdasasd 1.2.3.4 1.3.6.1.4.1.9.9.305.1.1.1
.1.3.6.1.4.1.9.9.305.1.1.1 = No Such Instance currently exists at this OID
-------- debug results from above snmpwalk: --------------
(Cisco Controller) >*SNMPTask: Jun 26 10:35:46.369: SNMPD: Packet from: 10.254.8.8:35594, in_packet_len = 48
*SNMPTask: Jun 26 10:35:46.369: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:35:46.369: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:35:46.369: SNMPD:calling do_response
*SNMPTask: Jun 26 10:35:46.369: Searching for next instance of cseSysCPUUtilization
*SNMPTask: Jun 26 10:35:46.369: Searching for next instance of cseSysMemoryUtilization
*SNMPTask: Jun 26 10:35:46.369: Searching for next instance of cseSysConfLastChange
*SNMPTask: Jun 26 10:35:46.369: Searching for next instance of cseSnmpErrorCode
*SNMPTask: Jun 26 10:35:46.369: Searching for next instance of cseSnmpErrorDescription
*SNMPTask: Jun 26 10:35:46.369: Searching for next instance of cLWlanRowStatus
*SNMPTask: Jun 26 10:35:46.369: SNMPD: Sending SNMP packet to 10.254.8.8:35594, out_packet_len = 52
*SNMPTask: Jun 26 10:35:46.370: SNMPD: Packet from: 10.254.8.8:35594, in_packet_len = 48
*SNMPTask: Jun 26 10:35:46.370: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:35:46.370: SNMPD: received get pdu
*SNMPTask: Jun 26 10:35:46.370: SNMPD:calling do_response
*SNMPTask: Jun 26 10:35:46.370: Searching for requested instance of cseSysCPUUtilization
*SNMPTask: Jun 26 10:35:46.370: SNMPD: Sending SNMP packet to 10.254.8.8:35594, out_packet_len = 48
(at this point nothing else happened. I disabled / re-enabled debug )
Next, tried:  snmpwalk -On -v2c -c asdasdasd 1.2.3.4 1.3.6.1.4.1.9.9.618.1
(The above walk returned values, see bottom of post for the results)
-------------- debug results from above walk ------------
*SNMPTask: Jun 26 10:36:44.573: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 46
*SNMPTask: Jun 26 10:36:44.573: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.573: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.573: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.573: Searching for next instance of clsDot3BridgeEnabled
*SNMPTask: Jun 26 10:36:44.573: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.574: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.574: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.574: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.574: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.574: Searching for next instance of clsDot3BridgeEnabled
*SNMPTask: Jun 26 10:36:44.574: Searching for next instance of clsDownloadFileType
*SNMPTask: Jun 26 10:36:44.574: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.574: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.575: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.575: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.575: Searching for next instance of clsDownloadFileType
*SNMPTask: Jun 26 10:36:44.575: Searching for next instance of clsDownloadCertificateKey
*SNMPTask: Jun 26 10:36:44.575: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 57
*SNMPTask: Jun 26 10:36:44.575: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.575: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.575: Searching for next instance of clsUploadFileType
*SNMPTask: Jun 26 10:36:44.576: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.576: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.576: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.576: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.576: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.576: Searching for next instance of clsUploadFileType
*SNMPTask: Jun 26 10:36:44.576: Searching for next instance of clsUploadPacUsername
*SNMPTask: Jun 26 10:36:44.576: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.577: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.577: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.577: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.577: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.577: Searching for next instance of clsUploadPacUsername
*SNMPTask: Jun 26 10:36:44.578: Searching for next instance of clsUploadPacPassword
*SNMPTask: Jun 26 10:36:44.578: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 57
*SNMPTask: Jun 26 10:36:44.578: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.578: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.579: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.579: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.579: Searching for next instance of clsUploadPacPassword
*SNMPTask: Jun 26 10:36:44.579: Searching for next instance of clsUploadPacValidity
*SNMPTask: Jun 26 10:36:44.579: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.580: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.580: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.580: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.580: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.580: Searching for next instance of clsUploadPacValidity
*SNMPTask: Jun 26 10:36:44.580: Searching for next instance of clsTransferConfigFileEncryption
*SNMPTask: Jun 26 10:36:44.581: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.581: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.581: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.581: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.581: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.581: Searching for next instance of clsTransferConfigFileEncryption
*SNMPTask: Jun 26 10:36:44.581: Searching for next instance of clsTransferConfigFileEncryptionKey
*SNMPTask: Jun 26 10:36:44.581: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.582: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.582: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.582: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.582: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.582: Searching for next instance of clsTransferConfigFileEncryptionKey
*SNMPTask: Jun 26 10:36:44.582: Searching for next instance of clsTimeZone
*SNMPTask: Jun 26 10:36:44.582: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.583: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.583: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.583: Searching for next instance of clsTimeZone
*SNMPTask: Jun 26 10:36:44.583: Searching for next instance of clsTimeZoneDescription
*SNMPTask: Jun 26 10:36:44.583: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 91
*SNMPTask: Jun 26 10:36:44.583: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.583: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.583: Searching for next instance of cLSysLogAddressType
*SNMPTask: Jun 26 10:36:44.583: Searching for next instance of cLSysLogHostRowStatus
*SNMPTask: Jun 26 10:36:44.583: Searching for next instance of cLSysArpUnicastEnabled
*SNMPTask: Jun 26 10:36:44.584: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.584: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.584: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.584: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.584: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.584: Searching for next instance of cLSysArpUnicastEnabled
*SNMPTask: Jun 26 10:36:44.584: Searching for next instance of clsTransferServerAddressType
*SNMPTask: Jun 26 10:36:44.584: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.585: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.585: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.585: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.585: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.585: Searching for next instance of clsTransferServerAddressType
*SNMPTask: Jun 26 10:36:44.585: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.586: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.586: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.586: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.586: Searching for next instance of clsTransferServerAddressType
*SNMPTask: Jun 26 10:36:44.586: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.586: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.587: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.587: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.587: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.587: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.587: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.587: Searching for next instance of clsTransferServerAddressType
*SNMPTask: Jun 26 10:36:44.587: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 57
*SNMPTask: Jun 26 10:36:44.588: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.588: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.588: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.588: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.588: Searching for next instance of clsTransferServerAddress
*SNMPTask: Jun 26 10:36:44.588: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 57
*SNMPTask: Jun 26 10:36:44.589: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.589: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.589: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.589: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.589: Searching for next instance of clsTransferServerAddress
*SNMPTask: Jun 26 10:36:44.589: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 57
*SNMPTask: Jun 26 10:36:44.590: Searching for next instance of clsTransferServerAddress
*SNMPTask: Jun 26 10:36:44.590: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 57
*SNMPTask: Jun 26 10:36:44.590: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.590: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.590: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.590: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.590: Searching for next instance of clsTransferPath
*SNMPTask: Jun 26 10:36:44.590: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 55
*SNMPTask: Jun 26 10:36:44.591: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.591: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.591: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.591: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.591: Searching for next instance of clsTransferPath
*SNMPTask: Jun 26 10:36:44.591: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 55
*SNMPTask: Jun 26 10:36:44.592: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.592: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.592: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.592: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.592: Searching for next instance of clsTransferPath
*SNMPTask: Jun 26 10:36:44.592: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 55
*SNMPTask: Jun 26 10:36:44.593: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 55
*SNMPTask: Jun 26 10:36:44.593: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.593: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.593: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.593: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.593: Searching for next instance of clsTransferPath
*SNMPTask: Jun 26 10:36:44.593: Searching for next instance of clsTransferFilename
*SNMPTask: Jun 26 10:36:44.593: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 76
*SNMPTask: Jun 26 10:36:44.594: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.594: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.594: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.594: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.594: Searching for next instance of clsTransferFilename
*SNMPTask: Jun 26 10:36:44.594: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 76
*SNMPTask: Jun 26 10:36:44.595: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.595: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.595: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.595: Searching for next instance of clsTransferFilename
*SNMPTask: Jun 26 10:36:44.595: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 76
*SNMPTask: Jun 26 10:36:44.595: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.596: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 76
*SNMPTask: Jun 26 10:36:44.596: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.596: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.596: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.596: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.596: Searching for next instance of clsTransferFilename
*SNMPTask: Jun 26 10:36:44.596: Searching for next instance of clsTransferFtpUsername
*SNMPTask: Jun 26 10:36:44.596: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.598: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.598: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.598: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.598: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.598: Searching for next instance of clsTransferFtpUsername
*SNMPTask: Jun 26 10:36:44.598: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.599: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.599: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.599: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.599: Searching for next instance of clsTransferFtpUsername
*SNMPTask: Jun 26 10:36:44.599: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.599: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.600: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.600: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.600: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.600: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.600: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.600: Searching for next instance of clsTransferFtpUsername
*SNMPTask: Jun 26 10:36:44.600: Searching for next instance of clsTransferFtpPassword
*SNMPTask: Jun 26 10:36:44.601: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.601: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.601: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.601: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.601: Searching for next instance of clsTransferFtpPassword
*SNMPTask: Jun 26 10:36:44.601: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.602: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.602: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.602: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.602: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.602: Searching for next instance of clsTransferFtpPassword
*SNMPTask: Jun 26 10:36:44.602: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.603: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.603: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.603: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.603: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.603: Searching for next instance of clsTransferFtpPassword
*SNMPTask: Jun 26 10:36:44.603: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.604: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.604: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.604: Searching for next instance of clsTransferFtpPassword
*SNMPTask: Jun 26 10:36:44.604: Searching for next instance of clsTransferFtpPortNum
*SNMPTask: Jun 26 10:36:44.604: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.604: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.604: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.605: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.605: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.605: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.605: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.605: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.605: Searching for next instance of clsTransferFtpPortNum
*SNMPTask: Jun 26 10:36:44.606: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.606: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.606: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.606: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.606: Searching for next instance of clsTransferFtpPortNum
*SNMPTask: Jun 26 10:36:44.606: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.607: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.607: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.607: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.607: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.607: Searching for next instance of clsTransferFtpPortNum
*SNMPTask: Jun 26 10:36:44.607: Searching for next instance of clsTransferTftpMaxRetries
*SNMPTask: Jun 26 10:36:44.607: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.608: Searching for next instance of clsTransferTftpMaxRetries
*SNMPTask: Jun 26 10:36:44.608: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.608: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.608: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.608: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.608: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.609: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.609: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.609: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.609: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.609: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.609: Searching for next instance of clsTransferTftpMaxRetries
*SNMPTask: Jun 26 10:36:44.610: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.610: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.610: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.610: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.610: Searching for next instance of clsTransferTftpMaxRetries
*SNMPTask: Jun 26 10:36:44.610: Searching for next instance of clsTransferTftpTimeout
*SNMPTask: Jun 26 10:36:44.610: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.611: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.611: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.611: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.611: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.611: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.611: Searching for next instance of clsTransferTftpTimeout
*SNMPTask: Jun 26 10:36:44.612: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.612: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.612: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.612: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.612: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.612: Searching for next instance of clsTransferTftpTimeout
*SNMPTask: Jun 26 10:36:44.613: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.613: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.613: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.613: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.613: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.614: Searching for next instance of clsTransferTftpTimeout
*SNMPTask: Jun 26 10:36:44.614: Searching for next instance of clsTransferStart
*SNMPTask: Jun 26 10:36:44.614: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.614: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.614: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.614: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.615: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.615: Searching for next instance of clsTransferStart
*SNMPTask: Jun 26 10:36:44.615: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.615: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.615: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.615: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.616: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.616: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.616: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.616: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.616: Searching for next instance of clsTransferStart
*SNMPTask: Jun 26 10:36:44.616: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.617: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.617: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.617: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.617: Searching for next instance of clsTransferStart
*SNMPTask: Jun 26 10:36:44.617: Searching for next instance of clsTransferStatus
*SNMPTask: Jun 26 10:36:44.617: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.617: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.618: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.618: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.618: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.618: Searching for next instance of clsTransferStatus
*SNMPTask: Jun 26 10:36:44.618: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.618: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.619: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.619: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.619: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.619: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.619: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.619: Searching for next instance of clsTransferStatus
*SNMPTask: Jun 26 10:36:44.620: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.620: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.620: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.620: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.620: Searching for next instance of clsTransferStatus
*SNMPTask: Jun 26 10:36:44.620: Searching for next instance of clsTransferStatusString
*SNMPTask: Jun 26 10:36:44.620: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.621: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.621: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.621: Searching for next instance of clsTransferStatusString
*SNMPTask: Jun 26 10:36:44.621: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.621: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.621: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.622: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.622: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.622: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.622: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.622: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.622: Searching for next instance of clsTransferStatusString
*SNMPTask: Jun 26 10:36:44.623: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 53
*SNMPTask: Jun 26 10:36:44.623: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.623: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.623: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.623: Searching for next instance of clsTransferStatusString
*SNMPTask: Jun 26 10:36:44.623: Searching for next instance of cLSysBroadcastForwardingEnabled
*SNMPTask: Jun 26 10:36:44.623: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.623: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.624: Searching for next instance of cLSysBroadcastForwardingEnabled
*SNMPTask: Jun 26 10:36:44.624: Searching for next instance of cLSysLagModeEnabled
*SNMPTask: Jun 26 10:36:44.624: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.624: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.624: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.624: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.624: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.624: Searching for next instance of clsConfigProductBranchVersion
*SNMPTask: Jun 26 10:36:44.625: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 49
*SNMPTask: Jun 26 10:36:44.625: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.625: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.625: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.625: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.625: Searching for next instance of clsConfigProductBranchVersion
*SNMPTask: Jun 26 10:36:44.625: Searching for next instance of clsConfigDhcpProxyEnabled
*SNMPTask: Jun 26 10:36:44.626: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.627: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.627: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.627: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.627: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.627: Searching for next instance of clsConfigDhcpProxyEnabled
*SNMPTask: Jun 26 10:36:44.627: Searching for next instance of cLSysMulticastIGMPSnoopingEnabled
*SNMPTask: Jun 26 10:36:44.627: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.628: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.629: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.629: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.629: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.629: Searching for next instance of cLSysMulticastIGMPSnoopingEnabled
*SNMPTask: Jun 26 10:36:44.629: Searching for next instance of cLSysMulticastIGMPSnoopingTimeout
*SNMPTask: Jun 26 10:36:44.629: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.629: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.630: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.630: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.630: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.630: Searching for next instance of cLSysMulticastIGMPSnoopingTimeout
*SNMPTask: Jun 26 10:36:44.630: Searching for next instance of cLSysMulticastIGMPQueryInterval
*SNMPTask: Jun 26 10:36:44.630: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.630: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.630: Searching for next instance of clsPortDot1dBasePort
*SNMPTask: Jun 26 10:36:44.631: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.631: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.631: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.631: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.631: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.631: Searching for next instance of clsPortDot1dBasePort
*SNMPTask: Jun 26 10:36:44.632: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.632: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.632: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.632: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.632: Searching for next instance of clsPortDot1dBasePort
*SNMPTask: Jun 26 10:36:44.632: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.633: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.633: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.633: Searching for next instance of clsPortDot1dBasePort
*SNMPTask: Jun 26 10:36:44.633: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.633: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.633: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.634: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.634: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.634: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.634: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.634: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.634: Searching for next instance of clsPortDot1dBasePort
*SNMPTask: Jun 26 10:36:44.635: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.635: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.635: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.635: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.635: Searching for next instance of clsPortDot1dBasePort
*SNMPTask: Jun 26 10:36:44.635: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.636: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.636: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.636: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.636: Searching for next instance of clsPortDot1dBasePort
*SNMPTask: Jun 26 10:36:44.636: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.636: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.636: Searching for next instance of clsPortModePhysicalMode
*SNMPTask: Jun 26 10:36:44.637: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.637: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.637: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.637: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.637: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.637: Searching for next instance of clsPortModePhysicalMode
*SNMPTask: Jun 26 10:36:44.638: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.638: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.638: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.638: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.638: Searching for next instance of clsPortModePhysicalMode
*SNMPTask: Jun 26 10:36:44.638: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.639: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.639: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.639: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.639: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.639: Searching for next instance of clsPortModePhysicalMode
*SNMPTask: Jun 26 10:36:44.639: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.640: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.640: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.640: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.640: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.640: Searching for next instance of clsPortModePhysicalMode
*SNMPTask: Jun 26 10:36:44.640: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.641: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.641: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.641: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.641: Searching for next instance of clsPortModePhysicalMode
*SNMPTask: Jun 26 10:36:44.641: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.641: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.642: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.642: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.642: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.642: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.642: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.642: Searching for next instance of clsPortModePhysicalMode
*SNMPTask: Jun 26 10:36:44.643: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.643: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.643: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.643: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.643: Searching for next instance of clsPortModePhysicalMode
*SNMPTask: Jun 26 10:36:44.643: Searching for next instance of clsPortModePhysicalStatus
*SNMPTask: Jun 26 10:36:44.643: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.644: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.644: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.644: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.644: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.644: Searching for next instance of clsPortModePhysicalStatus
*SNMPTask: Jun 26 10:36:44.644: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.645: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.645: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.645: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.645: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.645: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.645: Searching for next instance of clsPortModePhysicalStatus
*SNMPTask: Jun 26 10:36:44.646: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.646: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.646: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.646: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.646: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.646: Searching for next instance of clsPortModePhysicalStatus
*SNMPTask: Jun 26 10:36:44.647: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.647: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.647: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.647: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.647: Searching for next instance of clsPortModePhysicalStatus
*SNMPTask: Jun 26 10:36:44.647: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.648: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.648: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.648: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.648: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.648: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.648: Searching for next instance of clsPortModePhysicalStatus
*SNMPTask: Jun 26 10:36:44.649: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 53
*SNMPTask: Jun 26 10:36:44.649: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.649: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.649: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.649: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.649: Searching for next instance of clsPortModePhysicalStatus
*SNMPTask: Jun 26 10:36:44.649: Searching for next instance of clsPortModeSfpType
*SNMPTask: Jun 26 10:36:44.649: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 62
*SNMPTask: Jun 26 10:36:44.650: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.650: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.650: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.650: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.650: Searching for next instance of clsPortModeSfpType
*SNMPTask: Jun 26 10:36:44.650: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 62
*SNMPTask: Jun 26 10:36:44.651: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.651: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.651: Searching for next instance of clsPortModeSfpType
*SNMPTask: Jun 26 10:36:44.651: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 62
*SNMPTask: Jun 26 10:36:44.651: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.651: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.652: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 62
*SNMPTask: Jun 26 10:36:44.652: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.652: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.652: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.652: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.652: Searching for next instance of clsPortModeSfpType
*SNMPTask: Jun 26 10:36:44.652: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 63
*SNMPTask: Jun 26 10:36:44.653: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.653: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.653: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.653: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.653: Searching for next instance of clsPortModeSfpType
*SNMPTask: Jun 26 10:36:44.653: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 63
*SNMPTask: Jun 26 10:36:44.654: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.654: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.654: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.654: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.654: Searching for next instance of clsPortModeSfpType
*SNMPTask: Jun 26 10:36:44.654: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 63
*SNMPTask: Jun 26 10:36:44.655: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 63
*SNMPTask: Jun 26 10:36:44.655: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 52
*SNMPTask: Jun 26 10:36:44.655: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.655: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.655: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.655: Searching for next instance of clsPortModeSfpType
*SNMPTask: Jun 26 10:36:44.655: Searching for next instance of clsCoreDumpTransferEnable
*SNMPTask: Jun 26 10:36:44.655: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.656: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.656: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.656: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.656: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.656: Searching for next instance of clsCoreDumpTransferEnable
*SNMPTask: Jun 26 10:36:44.656: Searching for next instance of clsCoreDumpTransferMode
*SNMPTask: Jun 26 10:36:44.656: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.657: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.657: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.657: Searching for next instance of clsCoreDumpTransferMode
*SNMPTask: Jun 26 10:36:44.657: Searching for next instance of clsCoreDumpServerIPAddressType
*SNMPTask: Jun 26 10:36:44.657: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 51
*SNMPTask: Jun 26 10:36:44.657: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.657: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.658: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 54
*SNMPTask: Jun 26 10:36:44.658: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.658: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.658: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.658: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.658: Searching for next instance of clsCoreDumpServerIPAddress
*SNMPTask: Jun 26 10:36:44.658: Searching for next instance of clsCoreDumpFileName
*SNMPTask: Jun 26 10:36:44.658: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.659: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.659: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.659: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.659: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.659: Searching for next instance of clsCoreDumpFileName
*SNMPTask: Jun 26 10:36:44.659: Searching for next instance of clsCoreDumpUserName
*SNMPTask: Jun 26 10:36:44.659: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.660: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 50
*SNMPTask: Jun 26 10:36:44.660: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.660: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.660: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.660: Searching for next instance of clsCoreDumpUserName
*SNMPTask: Jun 26 10:36:44.660: Searching for next instance of clsCoreDumpPassword
*SNMPTask: Jun 26 10:36:44.660: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 55
*SNMPTask: Jun 26 10:36:44.661: Searching for next instance of clsCoreDumpPassword
*SNMPTask: Jun 26 10:36:44.661: Searching for next instance of clsConfigMulticastEnabled
*SNMPTask: Jun 26 10:36:44.661: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.661: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.661: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.661: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.661: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.661: Searching for next instance of clsCrashSystem
*SNMPTask: Jun 26 10:36:44.662: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.662: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.662: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.662: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.662: Searching for next instance of clsCrashSystem
*SNMPTask: Jun 26 10:36:44.662: Searching for next instance of cLSysLagModeInTransition
*SNMPTask: Jun 26 10:36:44.663: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.663: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.663: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.663: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.663: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.664: Searching for next instance of cLSysLagModeInTransition
*SNMPTask: Jun 26 10:36:44.664: Searching for next instance of clsEmergencyImageVersion
*SNMPTask: Jun 26 10:36:44.664: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 58
*SNMPTask: Jun 26 10:36:44.664: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.664: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.665: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.665: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.665: Searching for next instance of clsEmergencyImageVersion
*SNMPTask: Jun 26 10:36:44.665: Searching for next instance of clsAllCpuUsage
*SNMPTask: Jun 26 10:36:44.665: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 117
*SNMPTask: Jun 26 10:36:44.666: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.666: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.666: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.666: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.666: Searching for next instance of clsAllCpuUsage
*SNMPTask: Jun 26 10:36:44.666: Searching for next instance of clsSecStrongPwdCaseCheck
*SNMPTask: Jun 26 10:36:44.667: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.667: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.667: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.667: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.667: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.668: Searching for next instance of clsSecStrongPwdCaseCheck
*SNMPTask: Jun 26 10:36:44.668: Searching for next instance of clsSecStrongPwdConsecutiveCheck
*SNMPTask: Jun 26 10:36:44.668: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.668: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.668: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.669: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.669: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.669: Searching for next instance of clsSecStrongPwdConsecutiveCheck
*SNMPTask: Jun 26 10:36:44.669: Searching for next instance of clsSecStrongPwdDefaultCheck
*SNMPTask: Jun 26 10:36:44.669: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.669: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.669: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.669: Searching for next instance of clsSecStrongPwdAsUserNameCheck
*SNMPTask: Jun 26 10:36:44.670: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 50
*SNMPTask: Jun 26 10:36:44.670: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.670: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.670: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.670: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.670: Searching for next instance of clsSecStrongPwdAsUserNameCheck
*SNMPTask: Jun 26 10:36:44.670: Searching for next instance of clsSecStrongPwdCheckTrapEnabled
*SNMPTask: Jun 26 10:36:44.671: SNMPD: Packet from: 10.254.8.8:59581, in_packet_len = 49
*SNMPTask: Jun 26 10:36:44.671: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 26 10:36:44.671: SNMPD: received get-next pdu
*SNMPTask: Jun 26 10:36:44.671: SNMPD:calling do_response
*SNMPTask: Jun 26 10:36:44.671: Searching for next instance of clsSecStrongPwdCheckTrapEnabled
*SNMPTask: Jun 26 10:36:44.671: Searching for next instance of cllaActiveTimeout
*SNMPTask: Jun 26 10:36:44.671: SNMPD: Sending SNMP packet to 10.254.8.8:59581, out_packet_len = 52
(Cisco Controller) >debug snmp all disable
[zenoss]$ snmpwalk -On -v2c -c asasasas 1.2.3.4 1.3.6.1.4.1.9.9.618.1
.1.3.6.1.4.1.9.9.618.1.1.1.0 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.2.1.0 = INTEGER: 3
.1.3.6.1.4.1.9.9.618.1.1.2.2.0 = STRING: "*******"
.1.3.6.1.4.1.9.9.618.1.1.3.1.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.3.2.0 = ""
.1.3.6.1.4.1.9.9.618.1.1.3.3.0 = STRING: "*******"
.1.3.6.1.4.1.9.9.618.1.1.3.4.0 = Gauge32: 0
.1.3.6.1.4.1.9.9.618.1.1.4.1.0 = INTEGER: 0
.1.3.6.1.4.1.9.9.618.1.1.4.2.0 = ""
.1.3.6.1.4.1.9.9.618.1.1.5.1.0 = Gauge32: 6
.1.3.6.1.4.1.9.9.618.1.1.5.2.0 = STRING: "(GMT -7:00) Mountain Time (US and Canada)"
.1.3.6.1.4.1.9.9.618.1.1.7.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.3.1.1 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.3.1.2 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.3.2.1 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.3.2.2 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.4.1.1 = Hex-STRING: 0A FE 01 E6
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.4.1.2 = Hex-STRING: 0A FE 01 E6
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.4.2.1 = Hex-STRING: 0A FE 01 E6
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.4.2.2 = Hex-STRING: 0A FE 01 E6
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.5.1.1 = STRING: "./"
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.5.1.2 = STRING: "./"
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.5.2.1 = STRING: "./"
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.5.2.2 = STRING: "./"
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.6.1.1 = STRING: "ecb-5508-20120625a.tftp"
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.6.1.2 = STRING: "ecb-5508-20120625a.tftp"
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.6.2.1 = STRING: "ecb-5508-20120625a.tftp"
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.6.2.2 = STRING: "ecb-5508-20120625a.tftp"
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.7.1.1 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.7.1.2 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.7.2.1 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.7.2.2 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.8.1.1 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.8.1.2 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.8.2.1 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.8.2.2 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.9.1.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.9.1.2 = Gauge32: 0
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.9.2.1 = Gauge32: 0
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.9.2.2 = Gauge32: 0
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.10.1.1 = Gauge32: 10
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.10.1.2 = Gauge32: 10
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.10.2.1 = Gauge32: 10
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.10.2.2 = Gauge32: 10
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.11.1.1 = Gauge32: 6
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.11.1.2 = Gauge32: 6
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.11.2.1 = Gauge32: 6
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.11.2.2 = Gauge32: 6
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.12.1.1 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.12.1.2 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.12.2.1 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.12.2.2 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.13.1.1 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.13.1.2 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.13.2.1 = INTEGER: 12
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.13.2.2 = INTEGER: 12
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.14.1.1 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.14.1.2 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.14.2.1 = ""
.1.3.6.1.4.1.9.9.618.1.1.8.1.1.14.2.2 = ""
.1.3.6.1.4.1.9.9.618.1.1.9.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.10.0 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.11.0 = ""
.1.3.6.1.4.1.9.9.618.1.1.12.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.13.1.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.13.2.0 = Gauge32: 60
.1.3.6.1.4.1.9.9.618.1.1.13.3.0 = Gauge32: 20
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.1.1 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.1.2 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.1.3 = INTEGER: 3
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.1.4 = INTEGER: 4
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.1.5 = INTEGER: 5
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.1.6 = INTEGER: 6
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.1.7 = INTEGER: 7
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.1.8 = INTEGER: 8
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.2.1 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.2.2 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.2.3 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.2.4 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.2.5 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.2.6 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.2.7 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.2.8 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.3.1 = INTEGER: 9
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.3.2 = INTEGER: 9
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.3.3 = INTEGER: 9
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.3.4 = INTEGER: 9
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.3.5 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.3.6 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.3.7 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.3.8 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.4.1 = STRING: "1000BaseSX"
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.4.2 = STRING: "1000BaseSX"
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.4.3 = STRING: "1000BaseSX"
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.4.4 = STRING: "1000BaseSX"
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.4.5 = STRING: "Not Present"
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.4.6 = STRING: "Not Present"
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.4.7 = STRING: "Not Present"
.1.3.6.1.4.1.9.9.618.1.1.14.1.1.4.8 = STRING: "Not Present"
.1.3.6.1.4.1.9.9.618.1.1.15.1.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.15.2.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.1.15.3.0 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.15.4.0 = Hex-STRING: 00 00 00 00
.1.3.6.1.4.1.9.9.618.1.1.15.5.0 = ""
.1.3.6.1.4.1.9.9.618.1.1.15.6.0 = ""
.1.3.6.1.4.1.9.9.618.1.1.15.7.0 = STRING: "*****"
.1.3.6.1.4.1.9.9.618.1.1.16.0 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.1.99.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.2.1.0 = INTEGER: 2
.1.3.6.1.4.1.9.9.618.1.3.1.0 = STRING: "6.0.182.0"
.1.3.6.1.4.1.9.9.618.1.4.1.0 = STRING: "0%/0%, 0%/0%, 0%/0%, 0%/0%, 0%/0%, 0%/0%, 0%/0%, 0%/1%, 0%/0%, 0%/0%"
.1.3.6.1.4.1.9.9.618.1.5.1.0 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.5.2.0 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.5.3.0 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.5.4.0 = INTEGER: 1
.1.3.6.1.4.1.9.9.618.1.7.1.0 = INTEGER: 1
Steve
hello steve
I would say lets try on 7.2 and see how it goes , if nothing improved, have a TAC case opened to track this issue.
Hi;
Upgrading to the latest code did not change anything:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.2.110.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
Internal Temperature............................. +41 C
External Temperature............................. +22 C
Fan Status....................................... OK
[zenoss]$ snmpwalk -On -v2c -c asdasdasd 1.2.3.4 1.3.6.1.4.1.9.9.305.1.1.1
(Cisco Controller) >debug snmp all enable
(Cisco Controller) >*SNMPTask: Jun 29 11:01:32.528: SNMPD: Packet from: 10.254.8.8:59053, in_packet_len = 48
*SNMPTask: Jun 29 11:01:32.528: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 29 11:01:32.528: SNMPD: received get-next pdu
*SNMPTask: Jun 29 11:01:32.528: SNMPD:calling do_response
*SNMPTask: Jun 29 11:01:32.528: Searching for next instance of cseSysCPUUtilization
*SNMPTask: Jun 29 11:01:32.528: Searching for next instance of cseSysMemoryUtilization
*SNMPTask: Jun 29 11:01:32.528: Searching for next instance of cseSysConfLastChange
*SNMPTask: Jun 29 11:01:32.528: Searching for next instance of cseSnmpErrorCode
*SNMPTask: Jun 29 11:01:32.528: Searching for next instance of cseSnmpErrorDescription
*SNMPTask: Jun 29 11:01:32.528: Searching for next instance of cLWlanRowStatus
*SNMPTask: Jun 29 11:01:32.529: SNMPD: Sending SNMP packet to 10.254.8.8:59053, out_packet_len = 52
*SNMPTask: Jun 29 11:01:32.529: SNMPD: Packet from: 10.254.8.8:59053, in_packet_len = 48
*SNMPTask: Jun 29 11:01:32.529: SNMPD: calling srDoSnmp.
*SNMPTask: Jun 29 11:01:32.529: SNMPD: received get pdu
*SNMPTask: Jun 29 11:01:32.529: SNMPD:calling do_response
*SNMPTask: Jun 29 11:01:32.529: Searching for requested instance of cseSysCPUUtilization
It never gets past this point.
I hate having to open a TAC case.  If I do, is there any way to have the TAC engineer use this thread for all interaction on the case? I would save me a lot of copying and pasting.
Any other ideas?
Steve
5508 WLC - need MIB/OIDs for CPU utilization, other things
.1.3.6.1.4.1.9.9.618.1.4.1.0 – CPUs utilization with code 7.0 – attention each individual CPU is reported – we have 8 on the 5508.
Frédéric
13134
