5508 WLC upgrade
Looking to upgrade our 5508 WLC to the newest code AIR-CT5500-K9-7-2-103-0-FUS
We are currently running an older code  6.0.196.0
Are there any issues that I need to worry about with this upgrade ?
Do I need to upgrade the AP's at the same time ?
Cheers
Dave
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
5508 WLC upgrade
No you don't.  You upgrade the firmware of the WLC and the WLC will then push the appropriate code to the WAP in one go.
Re: 5508 WLC upgrade
Is the WLC going to be used in RUSSIA?  That's what this code is for.  If not, use the "AIR-CT5500-K9-7-2-103-0.aes" file instead.
The WLC will do it for you.
5508 WLC upgrade
Lol...Looks like I dl'd the wrong code...
Whoops.  You're too fast.  Updated my post, comrade.
5508 WLC upgrade
Downloaded correct code...:) So is it a pretty simple upgrade ? I have 25 AP's currently. Do I need to worry about the AP's as well ?
5508 WLC upgrade
5508 WLC upgrade
Updated the code all appears well except for one issue, which I will start another discussion for
Dave
5508 WLC upgrade
Thanks for the rating.
1049
