802.11x clients disconnecting from APs
Hey guys,
I am looking into some reports I have of users wifi dropping of causing interruptions to the the applications they are using.
The network they are connected on is a SSID which is secured using 802.11x. They all connect fine and seem to be connected correctly, but a lot of clients are frequently disconnected (they do manage to reconnect with a small drop in connectivity in between).
The time they can stay connected varies from device to device, but tends to be less than 10 minutes. Devices that stay in one location and dont roam at all are also experiencing these issues.
Below is the troubleshooting output from WCS for a client who is having this issue. It covers both the disconnection and then the clients reconnection a couple of minutes later.
08/23/2014 21:55:19 AKDT
ERROR
10.10.2.8
EAPOL-key is retransmitted.
08/23/2014 21:55:20 AKDT
ERROR
10.10.2.8
08/23/2014 21:55:21 AKDT
ERROR
10.10.2.8
De-authentication sent to client. slot 1 (claller 1x_ptsm.c:534)
ERROR
10.10.2.8
ERROR
10.10.2.8
EAPOL-key is invalid, scheduling client for deletion.
08/23/2014 21:55:41 AKDT
ERROR
10.10.2.8
De-authentication sent to client. slot 1 (claller apf_ms.c:5113)
INFO
10.10.2.8
Radius packet received. Accounting-Response received from RADIUS server 10.10.102.2, receiveId = 0
08/23/2014 21:59:50 AKDT
INFO
10.10.2.8
Controller association request message received.
INFO
10.10.2.8
Association request received from a client has an invalid RSN IE.(One reason could be mismatch in WPA2 algorithm).
INFO
10.10.2.8
The WLAN to which client is connecting requires 802 1x authentication.
INFO
10.10.2.8
Client moved to associated state successfully.
INFO
10.10.2.8
Received EAP Response from the client.
INFO
10.10.2.8
EAP response from client to AP received.
INFO
10.10.2.8
Radius packet received. Access-Challenge received from RADIUS server 10.10.10.20, receiveId = 2
INFO
10.10.2.8
Received Access-Challenge from the RADIUS server for the client.
INFO
10.10.2.8
Sending EAP request to client from radius server.
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
INFO
10.10.2.8
Radius packet received. Access-Accept received from RADIUS server 10.10.10.20, receiveId = 2
INFO
10.10.2.8
Received Access-Accept from the RADIUS server for the client.
ERROR
10.10.2.8
802.1x authentication message received, static dynamic wep supported.
INFO
10.10.2.8
Received eap success from the client.
INFO
10.10.2.8
802.1x authentication was completed successfully.
INFO
10.10.2.8
Client Moved to DHCP Required State.
08/23/2014 21:59:52 AKDT
INFO
10.10.2.8
Received DHCP request, received during mobility handshake.
08/23/2014 21:59:53 AKDT
INFO
10.10.2.8
Mobility role update request. from Unassociated to Local Peer = 0.0.0.0, Old Anchor = 0.0.0.0, New Anchor = 10.10.2.8
INFO
10.10.2.8
Mobility role changed. State Update from Mobility-Incomplete to Mobility-Complete, mobility role=Local, client state=APF_MS_STATE_ASSOCIATED
INFO
10.10.2.8
DHCP successful.
INFO
10.10.2.8
Client has got IP address, no L3 authentication required.
INFO
10.10.2.8
Client IP address is assigned.
INFO
10.10.2.8
08/23/2014 21:59:54 AKDT
INFO
10.10.2.8
Dhcp Information. transmitting DHCP REQUEST (3)
INFO
10.10.2.8
Dhcp Information. op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
INFO
10.10.2.8
Dhcp Information. xid: 0x5cd526b (97342059), secs: 5, flags: 0
INFO
10.10.2.8
Dhcp Information. chaddr: 1c:ab:a7:XX:XX:XX
INFO
10.10.2.8
Dhcp Information. ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
INFO
10.10.2.8
Dhcp Information. siaddr: 0.0.0.0, giaddr: 10.10.12.8
INFO
10.10.2.8
Dhcp Information. requested ip: 10.10.12.48
INFO
10.10.2.8
Received DHCP ACK ,dhcp server set.
INFO
10.10.2.8
Dhcp Information. transmitting DHCP ACK (5)
INFO
10.10.2.8
Dhcp Information. op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
INFO
10.10.2.8
Dhcp Information. xid: 0x5cd526b (97342059), secs: 0, flags: 0
INFO
10.10.2.8
INFO
10.10.2.8
Dhcp Information. ciaddr: 0.0.0.0, yiaddr: 10.10.12.48
INFO
10.10.2.8
Dhcp Information. siaddr: 0.0.0.0, giaddr: 0.0.0.0
INFO
10.10.2.8
Dhcp Information. server id: 1.1.1.1 rcvd server id: 10.10.10.20
Any ideas on where to start looking?
  • Security and Network Management
Everyone's tags (1)
1 REPLY
Hey,The controller disconnect
Hey,
The controller disconnect the client, but the reason is not clear.
Do you face this problem for 2.4 GHz / 5 GHz / both radios?
Have you noticed if it happened for clients connected to the same AP?
I think running (debug client <mac1, mac2, .. > would be more helpful to show what happened exactly)
If you were able to capture these debugs .. please share them here.
Cheers,
Nour
222
