802.1n slow with interface acl
hello
i'm testing an 802.1n 1250 AP with Cisco 4404 wlc and wisms (all running 5.1.151.0). pretty impressive speeds with intel 4965agn client. problem started when i added an acl on the wlc and applied it to the interface used by the 802.1n ssid. the acl slows the speed of the 802.1n network dramatically ( even if its one line of permit any any). has anyone else has this issue?
is it best practice to apply a wireless network acl on the controller itself or apply it on the vlan svi?
cheers
andy
Re: 802.1n slow with interface acl
Hii andrew
Applying ACL should not create performance issue. are you using any tool to measure throughput .
vinay ?
hi vinay
Thanks for the reply. I've been doing some throughput tests with Netcordia TTCP and got some interesting results. I've attached a network diagram to show where everything fits together. The WLC is a 4404 running 5.1.151.0 and the APS are 1130 and 1250.
The problem I'm having only happens when I apply an acl (simple permit ip any any) to the interface on the 4404.
Test 1
1250 SSID - wpa2/aes 802.1x, WMM policy set to required
Throughput results between servers and intel 4965agn without acl on SSID interface
Server A - Transmit: 8388608 bytes in 1642 milli-seconds = 5108.775 KB/sec (40870.2 Kbps).
Server B - Transmit: 8388608 bytes in 1953 milli-seconds = 4295.242 KB/sec (34361.938 Kbps).
Throughput results between servers and intel 4965agn with acl on SSID interface
Server A - Transmit: 8388608 bytes in 1622 milli-seconds = 5171.768 KB/sec (41374.145 Kbps).
Server B - Transmit: 8388608 bytes in 23500 milli-seconds = 356.96204 KB/sec (2855.6963 Kbps).
Throughput between Server A and the intel client is unaffected by applying the acl but the difference for Server B is pretty dramatic. Without acl the throughput is 34361.938 Kbps - with the acl it is 2855.6963 Kbps!
Test 2
1130 SSID wpa/tkip 802.1x
This test duplicated what was seen with the 1250. Applying acl only affected throughput between Server B and the intel client. With the 1130, Server B to intel client throughput dropped from 17972.379 Kbps to 1575.5474 Kbps.
Any ideas why this is happening? The links between the 4507s and 6509s are configured for QoS for an IPT pilot we are running.
Andy
Hi Andy,
Just looked at your description and tests. The problem is only observed with server B. Can you do one a test where there is no traffic from server A and send onoy traffic between server B and wireless client.
Also what kind of traffic is this tcp/udp? Can you also update the exact acl rule here as you mentioned it is permit ip any any, please paste the complete rule and also which direction you have applied this ACL?
Ankur
hi ankur
problem persists when only B is sending traffic. was using tcp port 80 with TCCP - full output from server Blooks like:-
Transmit: buflen= 8192 nbuf= 1024 port= 80
Transmit connection:
Socket[addr=/,port=80,localport=1620].
4507 A is a vtp domain server and has svi's configured. trunk link between 4507 and WLC 4404. the config on the 4404 is in xml format so hopefully the following output makes more sense.
output for 'show interface detailed 802dot1n_wireless'
Interface Name................................... 802dot1n_wireless
MAC Address...................................... XX:XX:XX:XX:XX:XX
IP Address....................................... XXX.XXX.XXX.XXX
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... XXX.XXX.XXX.XXX
VLAN............................................. 241
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (29)
Primary Physical Port............................ LAG (29)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. XXX.XXX.XXX.XXX
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. 8021n
AP Manager....................................... No
Guest Interface.................................. No
output for 'show acl detailed 8021n'
Source Destination Source Port Dest Port
I Dir IP Address/Netmask IP Address/Netmask Prot Range Range DSCP Action Counter
1 Any 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0 Any 0-65535 0-65535 Any Permit 732378
hope the above makes sense - let me know if you need any other info.
thanks
andy
Carried out more throughput tests with both the 1130 and 1250 APs:-
1130 802.11g
Without ACL on WLC interface:
Server B transmitting to Intel client: 19262Kbps
Intel client transmitting to Server B: 1384Kbps
With ACL on WLC interface:
Server B transmitting to Intel client: 3230Kbps
Intel client transmitting to Server B: 1274Kbps
By applying the ACL the 802.11g client's download throughput is 6 times slower - upload throughput is unaffected.
1250 802.11n
Server B transmitting to Intel client: 44475Kbps
Intel client transmitting to Server B: 53614Kbps
Server B transmitting to Intel client: 2495Kbps
Intel client transmitting to Server B: 54011Kbps
By applying the ACL the 802.11n client's download throughput is 18 to 20 times slower - upload throughput is unaffected.
I'll try upgrading WLC software to latest rev 5.2.157 and see if that improves things. If not I'll move ACLs off the WLC and apply them to the vlan svi's on the Catalyst 4507.
Cheers
Andy
Hii Andy
Can u plz chek the CPU and Memory utilisation when the throuput is down and lets compare with the normal situation.
Just wanted to make sure is the ACL taking much CPU .
thanks
Vinay
hi vinay
i've moved all the APs off the 4404 onto a WiSM so that the only associated APs are the 1130 and the 1250 i'm using for testing.
the 4404 is running at a memory usage of 32% and the CPU goes to 4% maximum when i'm running tests (i'm using cacti to poll the 4404 so i think these are 5 minute average values)
i'll try the latest software rev and post back.
thanks
andy
same problem with 5.2.157 - have rolled back to 5.1.151.0. i'll do some packet captures tomorrow. strange that applying acl on wlc only affects throughput from server B but not server A.
cheers
andy
hello
thought i'd try some older software revs on the wlc - rolled back to rev 5.0.148.2 and the results look pretty encouraging (compared to revs 5.2.157 and 5.1.151.0). results are for the 1250 802.11n
1250 802.11n
Server B transmitting to Intel client: 43544Kbps
Intel client transmitting to Server B: 50895Kbps
Server B transmitting to Intel client: 27287Kbps
Intel client transmitting to Server B: 44107Kbps
By applying the ACL the 802.11n client's download throughput is slightly slower - upload throughput is relatively unaffected.
is 5.0.148.2 the most 'stable' of 5.x or is there another rev worth trying?
thanks
andy
Silver
(never mind, misread)
562
