802.1x CCKM and Leap
Is there a way to use 802.1x PEAP as the authentication method and enable the client to use CCKM under the WDS or can you only use CCKM under LEAP authentication. I know you need a cisco card or a card that can do cisco compatible extensions but I would like to use 802.1x so we can take advantage of the ability for the pc to be able to log in under the machine account for maintenance purposes.
1 REPLY
Re: 802.1x CCKM and Leap
-- Cisco Fast Secure Roaming (which uses the CCKM protocol) only supports LEAP today.
-- Cisco does support the PEAP 802.1x type, but not for Fast Secure Roaming (CCKM).
-- More information on Fast Secure roaming is available at www.cisco.com/go/srnd (currently the last link on the page)
1643
