Bronze
802.1x multipoint authenticator and security issue
Hi everybody
Let say we have following set up:
host1
host2   ) ----------------hub------ f1/0-switch( authenticator)-------------------------Radius server.
host3
The switch is configured as follows.
Switch(config)#interface FastEthernet 1/0
Switch(config-if)#dot1x port-control auto
Switch(config-if)#dot1x host-mode multi-host
Let  say only host1 has valid credentials and the rest hosts i.e h2,h3 are  rogue hosts.  host1 sends authentication request and successfully  authenticated and switch transition its port to an authorized state.  But does it not mean  the other hosts h2 and h3 which were not  authenticated but yet are able to access network ?
thanks and have a great weekend.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: 802.1x multipoint authenticator and security issue
This board is more for Wireless Security not LAN. but I would think it's because you are connecting through a hub instead of a switch. Hubs share the data, so when the switch gets the auth for the valid client it turns that port as it should.
Now an invalid client connects and because the port is already thinking the client is valid, it passes all the traffic.
Make sense?
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
1 REPLY
Make sense?
Steve
200
