Community Member
802.1x *without* encryption. Is it possible ?
I have a ACU Client, WLC (with local EAP) and an external RADIUS server.
My aim is to use 802.1x, but WITHOUT encryption.
In the Cisco ACU, when I select 802.1x, I have to select an EAP type.
    With EAP-FAST, selected,
      On the WLC, if I enable local EAP, and  select WEP with No key size, it does not work.
      I have to select a Key size, therebye enabling WEP
         I believe this is because EAP-FAST *MANDATES* usign WEP or a 4 way handshake..
A. If I select other EAP types, and setup my authentication server (Free RADIUS) to support the EAP type,
    can I have a setup that can NOT use encryption ?
          On the WLC, do I just select 802.1x and a WAP key with 0 size ?
B. Is this not possible with any form of Local EAP ??
Re: 802.1x *without* encryption. Is it possible ?
Interesting question ...
I wonder why you would want to do that ...?
I just checked and it does look like you can do 802.1x with a wep key of NONE.
You may want to give that a shot ...
Please rate the post if you find this helpful
Community Member
Hi George,
Thats actually one of the first things I had tried, but it does not seem to work.
I repeated the test again, but this time with a sniffer running.
            I see the open auth/association go through, but it never proceeds to 802.1x (However this was with a all mixed cell flag on)
            Without that flag set, I dont see any packets from the client, except probe requests !!
On the controller, I was also running a debug aaa enable all, and dont see any activity, in both the above cases.
The moment I set the WEP key length from NONE to 104 bits, it works
I'll try with other clients, but I believe the result will be the same.
Also, this is just to get a better understanding of the behaviour of 802.1x.. Not for production.
Community Member
On Windows, 802.1x is not possible unless WEP is enabled.
Hall of Fame Super Silver
Not possible.... no encryption is having the ssid set to open or layer 2 security set to none.  802.1x usualy means some type of authentication to verify the user or device unless WEP is configured. Here is a link you might of seen already regarding different type s of authentication on the WLC:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807f42e9.shtml#auth-8201
Scott
-Scott
574
