i have a question.
i have a network with a Cisco WLC 5500, cisco 3500 and cisco 2960.
this network is opperating perfectly.
the have some wireless phones and these are not working fine, lose of connection.
Qos is configured on the network aswell as the WLC. the client wants some settings changed on the WLC:
Make sure they have A-MSDU disabled on the radios.
Can you have them disable A-MSDU transmissions on ALL priorities.
A-MSDU Tx:
Priority 0............................... Enabled -> Best Effort traffic
Priority 1............................... Enabled
Priority 2............................... Enabled
Priority 3............................... Enabled
Priority 4............................... Enabled- > SIP signaling traffic
Priority 5............................... Enabled
Priority 6............................... Disabled
Priority 7............................... Disabled
i don't know what this will do wil the rest of the wired network or wireless network.
can any body give my some advise
