02-22-2006 08:28 AM - edited 07-04-2021 11:41 AM
I have a customer with Cat6500 and WLSM running WDS. The APs and dot1x clients can authenticate with the ACS server. However, we cannot get any accounting information. We have tried configuring the WLSM with the following commands:
aaa accounting network default start-stop group ClientDevices
aaa accounting resource default start-stop group ClientDevices
aaa accounting auth-proxy default start-stop group ClientDevices
but none of these work. Devices are running the following code:
Cat6500/Sup720 - 12.2(18)SXD5
WLSM - 12.3(4)JA
1200APs - 12.3(7)JA2
Any assistance would be greatly appreciated.
Tracey
02-28-2006 07:25 AM
Looks like there is some configuration issue. Can you post the full configuration. This setup should work.
03-01-2006 01:37 AM
I set this up in the lab using an AP as the WDS and got the same problem; authentication logs but no accounting logs. Here are excerpts from the configs:
AP:
no aaa new-model
dot11 ssid eduroam
vlan 1800
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
mobility network-id 180
wlccp ap username xxxx password xxxx
wlccp ap wds ip address 172.30.2.174
WLSM:
aaa new-model
aaa group server radius AccessPoints
server 130.x.x.139 auth-port 1645 acct-port 1646
aaa group server radius ClientDevices
server 130.x.x.32 auth-port 1812 acct-port 1813
aaa authentication login Leap-devices group AccessPoints
aaa authentication login client-authentication group ClientDevices
aaa session-id common
radius-server host 130.x.x.32 auth-port 1812 acct-port 1813 key 7
radius-server host 130.209.13.139 auth-port 1645 acct-port 1646 key 7
wlccp authentication-server infrastructure Leap-devices
wlccp authentication-server client any client-authentication
wlccp wds interface Ethernet0/0.2
wlccp wnm ip address 172.20.18.58
The WLSM currently does not have any aaa accounting config. The following commands have been tried with no success:
Thanks for your help.
Tracey
11-30-2006 07:38 AM
Did you find a sollution?
I've seen the "radius-server vsa send accounting" commando - but couldn't make it work.
Greetings
Jarle
12-05-2006 01:50 AM
Hi Jarle,
Cisco advised that aaa accounting is not supported with WDS.
Sorry......Tracey
