04-21-2008 01:20 PM - edited 07-03-2021 03:45 PM
i was told that a 2006 controller can
authenticate WITHOUT using a radius server, or the like.
True/False?
Thanks, Gary
Solved! Go to Solution.
04-22-2008 05:40 AM
If you are a Microsoft shop, you can alway use IAS. Just bring it up on a seperate server or vmware.
04-22-2008 04:08 AM
The 4.2 code has the ability to do local eap. You will just have to try that out for yourself. Never tired it, since we always deploy with external radius server.
This link might help:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a008093f1b9.shtml
04-22-2008 05:33 AM
thanks for getting answering.
yeah, i'd REALLY would like a radius server but we don't have the expertise in house to run one, though.
By the way, for a small network, which radius platform would you recommend?
i'll read through the link, thanks. Gary
04-22-2008 05:40 AM
04-22-2008 05:41 AM
Mmmmm, that's a thought.
Thanks, Gary
04-22-2008 05:42 AM
It's free.... :)
Sort of..
