Access point associated and deassociated from WLC
HI,
i have 3 AP AIR-LAP1042N-E-K9 in the same place (Event at down town) but they Sometimes the APs even disassociate from the controller temporarily, and i see the below errors on Prime infrastructure 2.0
Load threshold violation reported by 802.11b/g/n interface of AP <apname>, connected to controller <controllerIP>
Interference threshold violation reported by '802.11b/g/n' interface of AP
Coveraged threshold violation reported by 802.11b/g/n interface of AP <apname>, connected to controller <controllerIP>
what these problems and how to solve it
Ahmed
VIP Purple
HI Ahmed,
it shows that, AP has more clients than the configured load threshold in another words, A radio interface of an access point is reporting that the client load has crossed a configured threshold.
you can change the the thresold vlaue from here:
wireless>802.11b/g/n>RRM>General
check this thread:
https://supportforums.cisco.com/message/3562909#3562909
Dont forget to rate helpful posts.
Hall of Fame Super Silver
Just to add... these errors on PI doesn't reflect the reason the AP has disassociated from the WLC.  The errors are just thresholds to send alerts to PI.  You will need to look somewhere else to see why the APs are disassociating with the WLC.  Check the ports on the switch and the logs also.  If you click on the AP from the GUI, you will see an uptime and a join time.  Uptime is how long its been powered and join time is how long it has been joined.  This can help to see if the AP is loosing power or maybe network connectivity issues causing the AP to loose connectivity to the WLC.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Re: Access point associated and deassociated from WLC
After these error done i see that error 802.11b/g/n interface of AP is down :controller.
please as example up time is 4:00 hours and join time changed every time may be once 12 m:15 sec, may be in another time 1h:15 m:20s
please feed me back these problem related to number of connected client because i monitor when the client exceed on AP more than 25 the AP deassociated from WLC.  kindly find loggs from AP. wait your feed back.
*Mar  1 00:00:11.913: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:11.916: *** CRASH_LOG = YES
Security Core found.
Base Ethernet MAC address: 6C:20:56:48:E7:59
*Mar  1 00:00:13.876: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:14.758: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:14.761: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:15.891: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:18.795: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1040 Software (C1140-K9W8-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 11-Dec-12 04:03 by prod_rel_team
*Mar  1 00:00:18.796: %SNMP-5-COLDSTART: SNMP agent on host 90013-03 is undergoing a cold start
*Mar  1 00:00:18.868: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:00:18.868: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:00:19.865: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:00:20.214: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:46.958: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:00:50.510: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:51.533: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:52.335: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.35.49.35, mask 255.255.255.248, hostname 90013-03
*Mar  1 00:00:52.533: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:52.559: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:00:53.559: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:01:03.221: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:13.236: %CAPWAP-3-ERRORLOG: Selected MWAR 'RMS-WLC1'(index 0).
*Mar  1 00:01:13.236: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Dec  9 09:54:50.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.94.70.2 peer_port: 5246
*Dec  9 09:54:50.919: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.94.70.2 peer_port: 5246
*Dec  9 09:54:50.920: %CAPWAP-5-SENDJOIN: sending Join Request to 10.94.70.2
*Dec  9 09:54:50.929: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Dec  9 09:54:50.929: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Dec  9 09:54:50.929: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Dec  9 09:54:50.930: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.94.70.2
*Dec  9 09:54:51.300: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec  9 09:54:51.355: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec  9 09:54:51.413: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller RMS-WLC1
*Dec  9 09:54:51.464: ac_first_hop_mac - IP:10.35.49.33 Hop IP:10.35.49.33 IDB:BVI1
*Dec  9 09:54:51.464: Setting AC first hop MAC: e804.62dc.9922
*Dec  9 09:54:51.465: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  9 09:54:51.595: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Dec  9 09:54:52.300: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec  9 09:54:52.383: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Dec  9 09:54:52.388: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec  9 09:54:52.464: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Dec  9 09:54:53.377: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec  9 09:54:53.409: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec  9 09:54:53.416: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Dec  9 09:54:53.421: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec  9 09:54:54.409: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Dec  9 09:54:54.416: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec  9 09:54:54.442: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  9 09:54:55.443: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec  9 10:26:53.849: %WIDS-4-SIG_ALARM: Attack is detected on Sig:Standard Id:5 Channel:11 Source MAC:905f.2e62.e7a9
*Dec  9 10:32:20.938: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(CAPWAP_WTP_EVENT_REQUEST
., 2)
*Dec  9 10:32:20.938: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Dec  9 10:32:20.938: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.94.70.2:5246
*Dec  9 10:32:20.994: %WIDS-6-DISABLED: IDS Signature is removed and disabled.
*Dec  9 10:32:20.997: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Dec  9 10:32:21.038: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Dec  9 10:32:21.039: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Dec  9 10:32:21.041: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec  9 10:32:21.113: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec  9 10:32:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.94.69.2 peer_port: 5246
*Dec  9 10:32:19.925: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Dec  9 10:32:19.927: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.94.69.2 peer_port: 5246
*Dec  9 10:32:19.928: %CAPWAP-5-SENDJOIN: sending Join Request to 10.94.69.2
*Dec  9 10:32:19.939: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Dec  9 10:32:19.939: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Dec  9 10:32:19.939: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Dec  9 10:32:19.939: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from 10.94.69.2
*Dec  9 10:32:20.093: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Dec  9 10:32:20.098: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec  9 10:32:20.370: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller UTO-WLC1
*Dec  9 10:32:20.424: ac_first_hop_mac - IP:10.35.49.33 Hop IP:10.35.49.33 IDB:BVI1
*Dec  9 10:32:20.424: Setting AC first hop MAC: e804.62dc.9922
I would open a TAC case then. I have seen other post in the past like this but can't find them. Since you already know what is causing the issue... Client count over 25, then TAC should be able to reproduce this or let you know if there is an open bug.
-Scott
Dears,
this case done when i put 3 Access point at down town and behind this APs found another access point from another companies.
the 3 AP up time fixed dont change the power always up but Controller Associated Time changed every time also all AP
disassociated from controller approximately at the same time the diferrence between every one may be from 2-5 minute and some time more than 1 hour find three AP up time and ass. time
UP Time
10 h 21 m 54 s
0 d, 01 h 42 m 27 s
UP Time
0 d, 09 h 55 m 38 s
0 d, 00 h 42 m 58 s
UP Time
0 d, 09 h 58 m 39 s
0 d, 02 h 09 m 41 s
Please find logg file from 3 AP. please advice if this problem related to peak time or number of user or connectivity issue or may be in the switch which connected to APs. knowing that i edit in performance profile for two AP increase the interference, clients, coverage,Coverage Exception Level and Client Min Exception Level i think without any effect (only ine effect the AP remain associated for long time but still down again)
thanks
Hall of Fame Super Gold
It's beginning to look like a faulty cable issue. Can you specify the exact model of your Cisco switch?
Sent from Cisco Technical Support Nintendo App
When this happens, what is the APs "uptime"? I am suspecting you have a faulty power source or faulty cable.
If this is the case, can you specify what is the exact model of your Cisco PoE switch?
I cant access the switch its for another company but Access point model AIR-LAP1042N-E-K9.
but i think if it cabling issue may be in one AP not in three at the same time
Yes it can.  I've witness to situations like these before.
Exactly what is the model of the Cisco switch your APs are directly connected?
one AP connected on SW 1841
and 2 AP connected on SW 2960
and today the same behaviour but i see when connected client increase the AP loose connectivity to WLC and the other 2 AP loose connectivity also after te first AP down (3 AP up time approximately same time 5 hour) but asscoiation join time deiffernt from one to another, please advice if this problem reated to Switch or access point or Connectivity issue and the loggs as the same yesterday.(already i upload it yesterday)
I'm not familiar with those model of switches nor am I sure if those model support TDR
You may need to run a TDR to determine if you have a faulty cable run.
1303
