Access Point Radios trying to authenticate via PEAP against ISE
I have a working installation including a 5508 controller with ISE. The ISE is configured for EAP Chaining and clients are authenticating fine.
We are seeing some weird behavior from the Access Points. We see authentication failures from devices trying to authenticate via PEAP, the funny thing is that the username and endpoint ID are the MAC addresses of our APs. we see it once or twice a day from several of the APs.
Any ideas on what would cause this and what function of the AP is causing this?
VIP Purple
Hi,How does "show radius
How does "show radius summary" output looks like specific to Acct & Auth Call statiion ID type.
Also what software code running on your WLC ?
Rasika
**** Pls rate all useful responses ****
Hi Rasika,kindly advice.
Hi Rasika,
kindly advice. running on 7.6.130 and Cisco ISE 1.2.1.198, but my case is rejected the authentication, why radio base mac address is try to authenticating to ISE?
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
(Cisco Controller) >show radius summary
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Acct Call Station Id Type........................ Mac Address
Auth Call Station Id Type........................ Mac Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
    Test Mode.................................... Off
    Probe User Name.............................. Radius_KeepAlive
    Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
Authentication Servers
Idx  Type      Server Address        Port    State     Tout  MgmtTout  RFC3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
1    NM    x.x.x.x              1645    Enabled   2     2         Disabled  Disabled - none/unknown/group-0/0 none/none
2    NM  x.x.x.x               1812    Enabled   2     2         Enabled   Disabled - none/unknown/group-0/0 none/none <-- ISE
3    NM    x.x.x.x             1645    Enabled   2     2         Disabled  Disabled - none/unknown/group-0/0 none/none
4    NM    x.x.x.x               1812    Enabled   2     2         Enabled   Disabled - none/unknown/group-0/0 none/none
<-- ISE
Accounting Servers
2      N    x.x.x.x               1813    Enabled   2     2         N/A       Disabled - none/unknown/group-0/0 none/none
3      N     x.x.x.x               1813    Enabled   2     2         N/A       Disabled - none/unknown/group-0/0 none/none
VIP Purple
Hi,Is it possible to change
Is it possible to change the Auth Call Station ID type to AP Radio MAC : SSID as shown below & test it.
(WLC) >show radius summary
Vendor Id Backward Compatibility......... Disabled
Call Station Id Case..................... lower
Acct Call Station Id Type................ Mac Address
Auth Call Station Id Type................ AP's Radio MAC Address:SSID
Rasika
102
