Bronze
accessing the edge router that is behind the ASA using an inside address
I have a router that is in front of our firewall (ASA5510) that I'd like to manage using an inside address. Is that possible?
Internet<--->router<--->ASA5510<--->Inside
router Interface facing the firewall has an ip address of 208.x.x.254
The firewall outside address is 208.x.x.253
The inside address that I'd like to use is 10.1.1.1
So, when an inside user wants to telnet to the router, he will use 10.1.1.1
i tried static (inside,outside) 208.x.x.254 10.1.1.1 netmask 255.255.255.255
but that does not seem to work.
1 REPLY
Re: accessing the edge router that is behind the ASA using an in
I would recommend modifying access to the edge router to use SSH as Telnet sends passwords in clear text.  Next create an ACL on the router so it can only be accessed for management via specific IP addresses associated with the ASA device.
310
