Community Member
ACL for Wireless Voice Vlan...
I am turning up a new wireless vlan using EAP-FAST for 7921's and 7925's. I am going to apply an ACL to the VLAN to prevent access to the servers or the network just incase someone makes it past the encryption.
Here is what I have but it doesn't seem to work. What am I leaving out?
IP access-list extended VLAN_100_OUTBOUND_ACL
permit icmp any any
permit udp 10.10.10.0 0.0.3.255 host 10.20.20.53 eq domain (DNS)
permit udp 10.10.10.0 0.0.3.255 host 10.20.20.52 eq bootps (DHCP)
permit tcp 10.10.10.0 0.0.3.255 host 10.20.20.52 eq 67 (DHCP)
permit udp 10.10.10.0 0.0.3.255 host 10.20.20.52 eq bootpc (DHCP)
permit tcp 10.10.10.0 0.0.3.255 host 10.20.20.52 eq 68 (DHCP)
permit tcp 10.10.10.0 0.0.3.255 host 10.30.20.50 eq 1812 (RADIUS)
permit udp 10.10.10.0 0.0.3.255 host 10.100.100.100 eq tftp (CALL MANAGER)
permit tcp 10.10.10.0 0.0.3.255 host 10.100.100.100 eq 2000 (CALL MANAGER)
permit tcp 10.10.10.0 0.0.3.255 host 10.100.100.100 eq www (CALL MANAGER)
permit tcp 10.10.10.0 0.0.3.255 host 10.100.100.100 eq 2443 (CALL MANAGER)
permit udp 10.10.10.0 0.0.3.255 any range 16384 32767 (PHONES)
deny ip any any
I also have another ACL for inbound that is just the opposite. I'm not sure what I need to add...
Thanks in advance.
Dave
Community Member
Re: ACL for Wireless Voice Vlan...
We used to use this one back when the phones only supported WEP.
ip access-list extended wireless_VoIP_ACL
permit udp any any eq 1985
permit ip any 172.27.246.0 0.0.1.255
permit udp any 172.16.2.0 0.15.253.255 range 16384 32767
permit udp any gt 1024 172.30.52.0 0.0.1.255 gt 1024
permit tcp any 172.30.52.0 0.0.1.255 eq 2000
permit udp any 172.30.52.0 0.0.1.255 eq tftp
permit udp any host 172.30.54.10 eq domain
permit udp any host 172.30.54.140 eq domain
permit udp any any eq 67
permit udp any any eq 68
deny ip any any
Hope this helps.
David, Can you fire me an email? I need to ask you a question...
242
