06-24-2007 09:25 AM - edited 07-03-2021 02:15 PM
hi
i want to generate self certificates and use peap but the message told me to copy and paste certificates on online enrollrmrnt tool ??
how can i do this
please advice
06-24-2007 10:22 AM
Here's how you do it,
Prem
06-25-2007 05:21 AM
Ahmed,
It seems that you are using acs 3.1. The self sign feature was introduced from ver 3.3, so you need to upgrade acs software.
Pls rate if helps !
~JG
06-25-2007 07:21 AM
JG is right,
this option was available from version 3.3(2) Build 2
Way to go JG!
Prem
