ACS 5.3 certificate VLAN AD mapping
we have ACS 5.3 and 1042 AP. So we need to authenticate client based on user certificate, and after that to put the client in specific VLAN based on membership in Active Directory group.
Is it possible to do that? We can not solve the problem of identity store, once the user is authenticated based on regular certificate, we need to authorize the same user based on the specific attribute from AD.
Thank You
Best regards,
Vladimir
1 REPLY
Hi Vladimir,
yes, you can do EAP-TLS authentication with attribute lookup against AD.
You have to configure an identity store sequence instead with authentication method certificate based and select AD for the retrieval of additional attributes. This sequence can be used in your access service as identity store.
hope that helps!
regards
Stefan
227
