ACS 5.3 - Suffix Stripping via PEAP (MS-Chapv2)
Is it possible to strip suffix on wireless client running PEAP (MS-CHAPv2). ACS version 5.3 (patch 5) - 5-3-0-40-5
Look like ACS 5.1 does not support this - see below link
https://supportforums.cisco.com/message/3272291#3272291
C
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
You did have it in your blog George:)
http://www.my80211.com/home/2011/11/8/cisco-acs-5x-radius-proxy-server-to-strip-prefix-or-suffix-u.html
-Scott
Hi Colmgrier,
When I get home I can post the step by step, but yes you can strip a prefix or suffix with acs 5.x. It does require some hokey pokey config, :).
You need to proxy the request after it being stripped.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
-Scott
Thanks Scott ! I forgot I posted that one ..
haha.... thats too funny:)
-Scott
Thanks for the below solution.
I have tested this and it is only working with wired radius client using PAP??
Wireless clients still failing using PEAP (MS-CHAPv2).
I will open a TAC case on Monday am.
Re: ACS 5.3 - Suffix Stripping via PEAP (MS-Chapv2)
Ok report back.. Curious to see what your issue is ...
ACS 5.3 - does not support PEAP (MS-CHAPv2). - confirmed by TAC.
ACS 4x has a 'special feature' (hack) to allow this.
I agree won't work out of the box. You need to set up a proxy like in my blog post.
Does not work using proxy - TAC explored all options.
I find that hard to believe .. I have it working on my network.
Are you using the NAM supplicant or the native supplicant? Also why are you wanting to strip the suffix is this for a multidomain environment?
Tarik Admani *Please rate helpful posts*
I followed the setup, and this does not appear to work when using PEAP MSCHAPv2 in ACS 5.3 and AD as the external identity store. Can somone please confirm if this is supposed to work with PEAP MSCHAP v2? Conflicting reports...
955
