ACS and CAR integration
Is it possible to integrate ACS and CAR with DB-2 Database and if yes, are there any limitations or issues related to that? Does CAR or ACS loose any functionality in such integration?
I am not looking for detailed process of the integration at this time, all I want to know is if it is supported and are there any issues.
Habib U Dashti
1 REPLY
Re: ACS and CAR integration
Hi Habib,
Yes, ACS can be integrated with DB-2, as ACS is ODBC compliant and so as DB-2, The other way round is that you can convert DB-2 database in flat file structure and import it into ACS database. Regarding limitations or issues i do not have any info.
And CAR has its own database & does not support DB-2.
Thanks.
234
