ACS/ LEAP and 7921G
I am having issues with our 7921G's authenticating through our ACS. I am using WCS to control two WiSM controllers. Currently, the SSID is set up to use WPA+WPA2 (AES and CCKM). The AAA settings point to our ACS server and I have LEAP authentication enabled and pointing to a profile. I have the phones configured with the same profile information but in ACS I get and error saying " EAP type not configured". I have gone through the phone and reset all passwords and verified the SSID. Can anyone advise on what to (re)check or where to look?
1 REPLY
Hall of Fame Super Silver
Re: ACS/ LEAP and 7921G
When you get that error on the ACS, it usually means that you didn't configure that EAP type the phones are using on the ACS itself. Try to get a laptop associated and authenticated first, before you try it on the phones.
-Scott
199
