ACS Passed Authentications
We've using a ACS Appliance 4.2, WLC 7.0.220, clients MS XP - NICs Cisco CB21
We seem to have some wireless deiveces that are authenticating in ACS every 20- 30 seconds.  The device is static, but seems to authenticate so many times.
Any ideas?
Cheers
Craig
Everyone's tags (2)
Hi Craig,
Idle wireless clients are prone to this re-authentication. Can you check if the busy wireless client do have the same problem?
Dave
Normally idle session timeout is default at 5 minutes 300 seconds.
I would check the client(s) in question. Compare the non issue clients with the issue clients.
What EAP are you using?
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
335
