Community Member
ACS Patch 5-1-0-44-3.tar.gpg already installed
When I try to install patch 5-1-0-44-3.tar.gpg from ftp repository message appear: Patch '5-1-0-44-3' is already installed.
% Error: Failure to open / validate the patch
But when I type sh ver:
Cisco ACS VERSION INFORMATION
Version : 5.1.0.44.2
Internal Build ID : B.2347
Patches :
5-1-0-44-1
5-1-0-44-2
Any idea?
Best regards
Fran
1 REPLY
Re: ACS Patch 5-1-0-44-3.tar.gpg already installed
Can you please share what is the command you are using to install the patch?
If you do "application acs stop" and then "application acs start", and try to install the patch. Does it throw the same message?
BR,
Tiago
640
