ACS upgrade from 5.2 to 5.4 on VM - urgently need your valuable advises
Hello all,
I need to upgrade ACS 5.2 to 5.4  patch 3. I got one ACS appliance and other one is on VM.  I'm concerning about the VM version when I upgrade the ACS from 5.2 to 5.4.  Will ACS work after I done the upgrade on the same VM ? What are the things that I should prepare before the upgrade?  What are the files that I have to download from smartnet?
Also please post a document of Matrix for supported VMs and ACS versions.
in the mean time I found two articles which are describing the system requirements.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-4/installation/guide/csacs_book/csacs_vmware.html#11288
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-2/installation/guide/acs5_2_install_guide/csacs_vmware.html#wp1056074
For the upgrade also do we need to have these specs on the VM server?  if yes I have to do is reimaging upgrade right?
Thank you for your valuable time and consideration
Kind regards
Chamara
Everyone's tags (4)
Hall of Fame Super Gold
Duplicate post.  Go here:
Duplicate post.
Go here:  https://supportforums.cisco.com/discussion/12222081/acs-upgrade-52-54-vm-urgently-need-your-valuable-advises
Page not found.  Do you have
Page not found.  Do you have any answer on this question please.
Bronze
Hi,1st thing you have post
1st thing you have post your query in wrong section.
Check below link for your 1st question.
https://supportforums.cisco.com/discussion/11823501/upgrade-acs-52-54
and for 2nd question yes you are right.
79
