ACS5.1 and PEAP. Use self-signed certificate generated by ACS?
I'm working with a customer who wants to run PEAP using MS-CHAPv2. They are using the Windows XP supplicant.
With prior versions of ACS (3.x, 4.x), I generated a self-signed cert on the ACS server itself and imported it onto the Windows machine.
Is this concept still valid with ACS5.1? (My customer opened a TAC case and the engineer said that the Cert must be from a external certificate authority.)
Thanks.
Everyone's tags (4)
Re: ACS5.1 and PEAP. Use self-signed certificate generated by AC
Hi kbyrd:
I'm looking at a self-signed cert from an ACS 5.1 box and it meets the version, EKU and server authentication criteria set out in the
EAP-TLS Deployment Guide for Wireless LAN Networks
http://tools.cisco.com/squish/A506C
document under section 5.2.2.  The server side cert is the same for both PEAP and EAP-TLS.
As long as the client isn't validating the server certificate, that should be fine.  I don't have an XP client to test with or I'd say more definitively.
Sincerely,
Rollin Kibbe
Network Management Systems Team
Thanks for your response, Rollin.
I could validate the self-signed cert if I exported it from the ACS and imported it into my Windows XP desktop. Correct? Thanks.
Hi kbyrd:
Yes, it's my understanding that's how it's supposed to work.  In order to do validation, the client has to have something to validate against.
Rollin
1617
