11-24-2003 04:44 AM - edited 07-04-2021 09:10 AM
ACU 6.2 is available since 11-17, but when i try to install it, a error message claim that i'm not a administrator of the system, even if i am the administrator. Any idea ?
Stéphane.
11-24-2003 05:00 AM
I had the same problem. i reinstalled windows 0)
but on my collegues laptop it worked fine.
regards Bernhard
11-24-2003 06:17 AM
And after reinstalling Windows, it's ok ?
For me, no... it seem it's like we cannot upgrade from 6.0 or 6.1 ... ?
11-24-2003 06:30 AM
i also wanted to upgrade from 6.1 but my collegue has also the 6.1 version an there it works.
bernhard
11-24-2003 11:43 PM
I have tested it now on my new XP laptop and it also doesnt work. =( i have the same issue: i need admin rights to install. but IM ADMINISTRATOR
does anybody hase a solution, maybe cisco? 0)
regards Bernhard
12-02-2003 06:02 AM
I have opened a tac case.
we now know that there is problem with the Windows if you dont have an english version. i have german. so the installation routine is checking the admin rights in english so all other windows (xp or 2000) with are not english doesnt work =) nice
Bernhard
12-05-2003 03:48 AM
It is a bug: CSCed14388
here is the description:
When installing Aironet client install wizard v1.2 for non-english based
Windows operating systems, user can expect to see the following Windows
error message.
Administrator priveleges are required to run the installation. Please log
in as an administrator to run this installation Select OK to exit
Workaround : Running individual setup.exe component within ACIWv1.2 works
as well as ALL English based Windows OS.
bernhard
01-18-2004 07:56 AM
Hello ,
this is a bug, I opend a Case at the TAC and get later a new Client Utility Wizard. The reason was
that, especially in no english WINDOWS (2K/2000) versions a problem with the istall routine is.
Please send me your e-mail address and I give you a FTP account, because this file is approx. 13 MB big and our company mail system allow only 10 MB.
regards
