Adding (dynamic) interfaces to WLC 2504 causes loss of network
3moloz123
I'm trying to add a new dynamic interface, that I will tie a specific WLAN to so that clients on that WLAN is in the correct vlan. After adding it I loose connectivity both to the main management address (10.99.0.60) and to the ip address of the dynamic interface (10.99.12.4). In fact, the dynamic interface address responds and prompts me to login, but after doing so all I get is a blank page. Here's the two interfaces pulled from the CLI - what am I doing wrong?
And oh, not adding an IP to the dynamic interface makes it impossible to use within a WLAN.
Interface Name................................... management
MAC Address...................................... c0:8c:60:c7:99:00
IP Address....................................... 10.99.0.60
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.99.0.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 31
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
DHCP Proxy Mode.................................. Global
Primary DHCP Server.............................. 10.99.0.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
IPv4 ACL......................................... Unconfigured
mDNS Profile Name................................ Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
L2 Multicast..................................... Enabled
Interface Name................................... lan
MAC Address...................................... c0:8c:60:c7:99:04
IP Address....................................... 10.99.12.4
IP Netmask....................................... 255.255.252.0
IP Gateway....................................... 10.99.12.1
VLAN............................................. 33
NAS-Identifier................................... mob-wlc
Primary DHCP Server.............................. Unconfigured
AP Manager....................................... No
17 Replies 17
Sandeep Choudhary
Try to use this mask: 255.255.255.0 for lan dynamic interface and then try and then map this dynamic interface to your WLAN.
1) the netmask should not be 255.255.255.0, it's a /22 network
2) I lose contact with the WLC completely, except via console. I did manually change so that mytestssid-wlan now uses the "lan" (dynamic) interface. Still no management gui access though ..
(Cisco Controller) >show interface summary
 Number of Interfaces.......................... 3
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       1    31       10.99.0.60      Static  Yes    No
lan                       2    33       10.99.12.4      Dynamic No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
(Cisco Controller) >show wlan summary
Number of WLANs.................................. 2
WLAN ID  WLAN Profile Name / SSID               Status    Interface Name
2        yo dude / yo dude                      Enabled  management
(Cisco Controller) >config wlan interface 2 mobengalan
2        mytestssid / mytestssid                Enabled  lan
You are using the port for 2 for lan wlan.
Change the port to 1 and make sure that all vlan are allowed on the sitchport where wlc is connected.
Check the ink for dynamic interface configuration.
http://rscciew.wordpress.com/2014/01/22/configure-dynamic-interface-on-wlc/
Yes, I know. I first tried port 1 (same as management) but to no avail, thereafter I tried a dedicated port. What baffles me is that I lose management access. A restart (which disables the dynamic interface) fixes that - any suggestions?
So take a look at this. I have the dynamic interface used in wlan 2 (mytestssid as shown above). Now the management address, 10.99.0.60 cant be reached:
Nmap scan report for 10.99.0.60
Host is up.
PORT    STATE    SERVICE
22/tcp  filtered ssh
443/tcp filtered https
After removing wlan 2 and the dynamic interface, mgmt access starts to work again:
config wlan disable 2
config wlan delete wlan 2
config interface delete lan
Host is up (0.0037s latency).
PORT    STATE SERVICE
22/tcp  open  ssh
443/tcp open  https
So... here's me adding the dynamic interface in cli AGAIN:
1        someotherssid / someotherssid              Enabled   management
(Cisco Controller) config> interface create lan 33
(Cisco Controller) config> interface address dynamic-interface lan 10.99.12.4 255.255.252.0 10.99.12.1
(Cisco Controller) >config wlan disable 1
(Cisco Controller) >config wlan interface 1 lan
(Cisco Controller) >config wlan enable 1
Voila, management access lost again:
Host is up.
PORT    STATE    SERVICE
22/tcp  filtered ssh
This time, there's no physical port assigned to the dynamic interface 'lan':
lan                              -    33       10.99.12.4      Dynamic No     No
Adding that:
(Cisco Controller) config interface port lan 1
lan                              1    33       10.99.12.4      Dynamic No     No
Still no management access..:
Host is up.
PORT    STATE    SERVICE
22/tcp  filtered ssh
For reference, the detailed interface config (which clearly shows that 'management' should be ap mgmt.. and dynamic interface 'lan' shouldn't (and thus shouldn't affect it - RIGHT?)):
By the way, the switchport of my (C3560G) doesnt specifically allow some VLANs - meaning they allow all vlans:
interface GigabitEthernet0/28
 description cisco_wlc
 switchport mode trunk
And the vlans in question are present:
31   enet  100031     1500  -      -      -        -    -        0      0
32   enet  100032     1500  -      -      -        -    -        0      0
33   enet  100033     1500  -      -      -        -    -        0      0
34   enet  100034     1500  -      -      -        -    -        0      0
HI ,
Use swicth port config as:
 switchport trunk allowed vlan 31,33
Try to keep both interafce on same port 1.
Dont forget to rate ehlpful posts
No difference (because not using 'allowed vlan' implies all vlans are allowed).
Dont know, why its happening.
Must check via teamviewer(Only if you want then send me a private message).
Dont forget to rate helpful posts
I wouldn't expect that. I have a ccie consultant coming next week to take a look at it, but if you don't mind sure. I can't find out how I can message you, though?
Clcik your name on the right side of the main community page. There you cans ee the Message tab.
I just send u PM chekc it.
Exclude management vlan from Port 2, if it is trunk or try and use the the second port just as access (then vlan ID on WLC interface would be 0) and exclude the port 2 access vlan from trunk on port 1.
Best,
Sumit
Did you manage to get it working? I have similar issues. thanks!
I also have the same issue....
This is not normal. Maybe check the code your running and upgrade and search the bug toolkit.
-Scott
-Scott
