after autonomous AP upgrade to LWAPP it keeps reboot
jerryben11
My autonomous AP1231 is running software version 12.3(7), then i upgrade it with c1200-rcvk9w8-tar.123-7JX.tar and c1200-rcvk9w8-tar.123-11JX1.tar, after that, both version will make my AP keep reboot for around every 20 secs with the following error msg
Mar 1 00:00:24.401: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:25.418: LWAPP_CLIENT_ERROR_DEBUG: lwapp_crypto_init_ssc_keys_and_c
erts no certs in the SSC Private File
*Mar 1 00:00:25.419: LWAPP_CLIENT_ERROR_DEBUG:
*Mar 1 00:00:25.419: lwapp_crypto_init: PKI_StartSession failed
*Mar 1 00:00:25.419: %SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Re
ason: FAILED CRYPTO INIT.
*Mar 1 00:00:25.420: %LWAPP-5-CHANGED: LWAPP changed state to DOWNXmodem file s
ystem is available.
Any way to solve it?
Thank you
Scott Fella
When you used the upgrade tool to convert the 1231 to lwapp, did you add the ssc to the wlc? If not, then your ap will never join and will keep rebooting.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00806a426c.shtml
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072d9a1.shtml
-Scott
