AIR-AP1220B-E-K9 conversion to LWAPP?
Hi guys,
do any of you know if you can convert a AIR-AP1220B-E-K9 to a LWAPP?
System firmware 12.01a
Internal Radio firmware 5.02.12
Thanks in advance
Mark
1 ACCEPTED SOLUTION
Re: AIR-AP1220B-E-K9 conversion to LWAPP?
I was able to, it was more involved than most, you need to upgrade the IOS to 12.3.7, and replace the radio with a newer B/G. once those two items are down, run the upgrade utility, cut and paste the mac and created Key to your WLC and your up
Hi Mark,
Have a look at this link and search for keyword "Solution Requirements"
http://www.cisco.com/en/US/products/hw/wireless/ps430/prod_technical_reference09186a00804fc3dc.html#wp23144
Ankur
*Pls rate all helpfull post
425
