AIR-CAP1532I in a non-mesh environment
Hi.
I'm trying to get a CAP1532I working as a "normal access point" and not in a mesh environment.
Is that possible?
If I try to get the AP joining our controller ( 5508 with 7.6.120.0 ), I get these errors:
*Mar  1 00:02:27.495: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Aug 20 10:22:44.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: XX peer_port: 5246
*Aug 20 10:22:44.515: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: XX peer_port: 5246
*Aug 20 10:22:44.515: %CAPWAP-5-SENDJOIN: sending Join Request to XX
*Aug 20 10:22:44.519: %CAPWAP-3-ERRORLOG: Invalid event 10 & state 5 combination.
*Aug 20 10:22:44.519: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 10 state 5.
*Aug 20 10:22:44.519: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Aug 20 10:22:44.519: %CAPWAP-3-ERRORLOG: Failed to process encrypted capwap packet from XX
*Aug 20 10:22:49.515: %CAPWAP-5-SENDJOIN: sending Join Request to XX
*Aug 20 10:23:43.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to XX:5246
*Aug 20 10:23:44.031: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led state 255
*Aug 20 10:23:44.083: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Aug 20 10:23:44.119: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Aug 20 10:23:45.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Aug 20 10:23:45.139: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Aug 20 10:23:46.139: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
IP of the controller is correct through DHCP.
We don't have any mesh access points in our network and I don't think that would be possible because we have more than one country code registred.
No information in the controller log, so I don't know what to do now.
Does anyone has an idea?
Sven
1 ACCEPTED SOLUTION
VIP Purple
Hi,You may try this:Change
You may try this:
Change the 1532i image to Normal Local mode by uploading a standard recovery image.
More info on AP images: http://rscciew.wordpress.com/2014/01/04/understand-access-point-ios-images/
1. Download "ap1g3-k9w8-tar.152-4.JB3.tar" or the new one "ap1g3-k9w8-tar.153-3.JA.tar"this from CCO
2. Rename it as ap1g3-k9w7-tar.default.
3. Directly connect AP ethernet to your laptop where laptop configured as 10.0.0.2/8 (with GW 10.0.0.1) & run a TFTP server on your PC.
4. Power the AP using injector while hold the RESET button for 20-30s
5. Release the RESET button & monitor the console output of your AP, you should see AP load the new image & deleting the existing one.
6. Then connect it to your network, it should register as a local mode AP.
Below explain usage of RESET button
http://www.cisco.com/en/US/docs/wireless/access_point/1530/installation/guide/1530_ch3.html#wp1112590
This post also shoud help you on this process.
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Dont forget to rate helpful posts
VIP Purple
Hi,Did you add the mac
Think that its with mesh image. yes its support local mode.
Did you add the mac address of AP to WLC ?
Add the MAC Address of the Mesh AP to the MAC Filter of the Controller
Choose Security > AAA > MAC Filtering
Click New. The MAC Filters > New page appears. Enter the MAC address of the mesh access point
From the Profile Name drop-down list, choose Any WLAN.
From the Interface Name drop-down list, choose Management interface.
after this you can change the mode of AP from bridge to local.
wireless > Access Points > All APs  click on specific AP and then go under gerneral tab, there you will see AP mode. by drop down you can change it to local mode.
Still getting probs then paste the output of these commands:
sh version from AP
sh sysinfo from WLC
Hello Sandeep.I already added
Hello Sandeep.
I already added the MAC address to the filter.
I did everything that was in the configuration guide.
Here is the further information:
sh version
Cisco IOS Software, C1530 Software (ap1g3-K9W8-M), Version 15.2(4)JB3b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 23-Jan-14 21:52 by prod_rel_team
ROM: Bootstrap program is C1530 boot loader
BOOTLDR: C1530 Boot Loader (ap1g3-BOOT-M) Version 15.2(4)JB3b, RELEASE SOFTWARE (fc1)
AP78da.6e60.8a72 uptime is 3 minutes
System image file is "flash:/ap1g3-k9w8-mx.152-4.JB3b/ap1g3-k9w8-mx.152-4.JB3b"
Last reload reason: Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP1532I-E-K9 (MIPS74k) processor (revision 28) with 204800K/57344K bytes of memory.
Processor board ID FCZ1825H059
MIPS74k CPU at 700Mhz, revision number 0x0000
Last reset from power-on
LWAPP image version 7.6.95.12
2 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 78:DA:6E:60:8A:72
Part Number                          : 74-11942-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC182280HQ
Top Assembly Part Number             : 000-00000-00
Top Assembly Serial Number           : FCZ1825H059
Top Revision Number                  : 23
Product/Model Number                 : AIR-CAP1532I-E-K9
Configuration register is 0xF
sh sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.120.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.112.21
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... XX
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO (Both AP and Client SSO)
IP Address....................................... XX
Last Reset....................................... Software reset
System Up Time................................... 10 days 1 hrs 7 mins 54 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries:AT,BG,BR,CH,CN,CZ,DE,DK,FI,FR,GB,HK,IT,JP,KR,NL,NO,PL,SE,SK
--More-- or (q)uit
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +27 C
External Temperature............................. +22 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 15
Number of Active Clients......................... 563
Burned-in MAC Address............................ 2C:54:2D:72:60:C0
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 500
Sven
VIP Purple
By default this AP have mesh
By default this AP have mesh image and mesh AP can not join multi country configured Controller.
if you dont have much APs then you can remove country code except one and then try to connect and change its mode to local then conifigure the all country code again.
Hello. I have about 250
Hello.
I have about 250 access points in 16 different countries and to change the country codes, you need to disable all radios, so that's not possible.
Is there any other way to get a non-mesh image or configuration on the access point?
VIP Purple
Hi,As per my knowledge there
As per my knowledge there is no other method.
If you have another WLC(Secondary or backup) then try to connect to it and after adding convert this AP from bridge to Local , then connect with main controller.
REgards
HiI don't have another
I don't have another controller. My second/backup controller runs in HA with the main controller.
Hope that there is another soultion for that.
If I knew that befor I bought the AP, I wouldn't have done it.
VIP Purple
You may try this:
Hi.Thanks for the hint.I will
Hi.
I will try this out.
Hi!The new image ap1g3-k9w8
Hi!
The new image ap1g3-k9w8-tar.153-3.JA.tar seems to have a problem. Got some image errors when trying with it.
The older image and your instructions worked fine. AP was in local mode and was able to connect to the WLC.
Thank you very much!
Sven
1283
