AIR-CT5508-K9 License gone after upgrading to 7.4.100.0
We have a wierd issue with our 5508 WLC which has a AP base count of 250.
right now we're running code version 7.4.100.0 with 75 active AP's connected
The license details:
I tried twice to upgrade to code version 7.5.102.0 but in both cases the base license disappeared after the upgrade as you can see:
(Cisco Controller) >show license all
License Store: Evaluation License Storage
StoreIndex:  0  Feature: base-ap-count                     Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period:  8 weeks  4 days
            Evaluation period left:  8 weeks  4 days
        License Count: 500 / 0 (Active/In-use)
        License Priority: None
(Cisco Controller) >show license udi
Device# PID                     SN                      UDI
*0      AIR-CT5508-K9           FCW1526xxxx            AIR-CT5508-K9:FCW1526xxx
(Cisco Controller) >show license file
  Store Index: 0
    License: 11 base-ap-count 1.0 LONG TRIAL DISABLED 1440 DISABLED STANDALONE
              ADD 500_KEYS INFINITE_KEYS NEVER NEVER NiL SLM_CODE DEMO NiL NiL
              Ni NiL NiL 5_MINS NiL MdJd10O,mtIZ6NbE6Wz4L7mlRpB1ORkKam6zeH6MTA
             f:ANiieo1Z<---cut--->5lF03hp
             csLJVYkat3KCLOPYJNrPo3H6kt5cbt8q4XJ46naeRqwInXo3s+nsLU7rOtdOxoIxY
             ZAo3LYmUJ+MFzsqlhKoJVlPyEvQ8H21MNUjVbhoN0gyIWsyiJaM8AQIkVBQFzhr10
             GYolVzdzfJfEPQIx6tZ++/Vtc/q3SF/5Ko8XCY=</WLC>
    Comment:
       Hash: 4RHF2Mhn<---cut--->w3KFoVG4=
therefor we're unable to connect AP's anymore.
did not find any bug related to that issue or any information in the releasenote which could explain that behaviour.
any ideas?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Send an email to license@cisco.com.  Provide the serial number of your appliance and they can verify what is your true license.
.. i meant "
AIR-CT5508-K9 License gone after upgrading to 7.5.102.0
in the title, not 7.4.100. could please someone correct this typo
Thanks that helped me out. I contacted cisco license team and they sent me a custom license file.
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.5.102.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.112.21
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... xxxxx
System Location.................................. Zuerich
System Contact................................... xxxxx
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... xxxxx
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 7 mins 19 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... CH  - Switzerland
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +43 C
External Temperature............................. +26 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 8
Burned-in MAC Address............................ 30:F7:0Dxxxxxx
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 250
License Store: Primary License Storage
StoreIndex:  2  Feature: base                              Version: 1.0
        License Type: Permanent
        License Count: Non-Counted
        License Priority: Medium
StoreIndex:  3  Feature: base-ap-count                     Version: 1.0
        License State: Active, In Use
        License Count: 250 /250 (Active/In-use)
        License State: Inactive
--More-- or (q)uit
Thanks for taking the time to rate our posts, Samuel.
544
