Aironet 1140G Gateway issues
Hallo Community!!!
I have a problem with my Aironet 1140G (autonomous).
1. i cannot ping the bvi1 interface ip (172.20.200.5)
2. the aironet doesnot use the default gateway
I would like to check the system status via snmp, the snmp server is in another subnet  (aironet ip: 172.20.200.6; snmpserver: 192.168.5.5) The snmp server cannot ping the Aironet. There are no acl on the way. The snmp server can ping a client (172.20.200.151).
Where is the problem can anybody help me?
My configuration:
hostname XXXXXXXXXXXXXXXX
logging console notifications
enable secret 5 $1XXXXXXXXXXXXXXXOK/
aaa new-model
aaa group server radius ADAUTH
server-private 192.168.XXX24 auth-port 1645 acct-port 1646 key 7 00XXXXXXXXXXXXXXX5E
server 192.168XXXX.24 auth-port 1645 acct-port 1646
aaa authentication login default local
aaa session-id common
clock timezone +0100 1
ip domain name XXXXXXXXXXXXX
ip name-server 192.168.5.11
ip name-server 192.168.5.10
dot11 syslog
dot11 ssid XXXXXXXXXXXXX
   vlan 993
   authentication open
   authentication key-management wpa version 2
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 1XXXXXXXXXXXXXXXXXXXX9
dot11 ssid systemsXXX
   vlan 1220
   authentication open
   wpa-psk ascii 7 1456250EXXXXXXXXXXXXXXXXXX19
dot11 ssid systems.XXx
   vlan 1210
   authentication open
   wpa-psk ascii 7 145XXXXXXXXXXXXXXXXXXE12
dot11 ssid systemsXXXX
   vlan 1200
   authentication open
   wpa-psk ascii 7 0XXXXXXXXXXXXXXXXXXXXXXX72
dot11 ssid systeXXXX
   vlan 1230
   authentication open
   wpa-psk ascii 7 0247335E0705002C491C3A00160317061F4A27382769
dot11 network-map
crypto pki trustpoint TP-self-signed-38XXXX975
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-38XXXXX
revocation-check none
rsakeypair TP-self-signed-3850784975
crypto pki certificate chain TP-self-signed-385XXXX75
certificate self-signed 01
  3XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
quit
username Cisco password 7 09XXXXX
username admin privilege 15 password 7 XXXXXX
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 993 mode ciphers aes-ccm
encryption vlan 1200 mode ciphers aes-ccm
encryption vlan 1210 mode ciphers aes-ccm
encryption vlan 1220 mode ciphers aes-ccm
encryption vlan 1230 mode ciphers aes-ccm
ssid XXXXXXXXXXXXXXXXX
ssid systems.XX
ssid systems.XXX
ssid systems.XXXX
ssid systems.XXXXX
antenna gain 0
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
power local 8
power client 8
packet retries 128 drop-packet
channel least-congested 2412 2437 2462
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.993
description fhbhotspot
encapsulation dot1Q 993
ip access-group XXXXXXXXXXX_acl in
no ip route-cache
bridge-group 7
bridge-group 7 subscriber-loop-control
bridge-group 7 block-unknown-source
no bridge-group 7 source-learning
no bridge-group 7 unicast-flooding
bridge-group 7 spanning-disabled
interface Dot11Radio0.1200
description systems.XXXX
encapsulation dot1Q 1200
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.1210
encapsulation dot1Q 1210
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio0.1220
encapsulation dot1Q 1220
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface Dot11Radio0.1230
encapsulation dot1Q 1230
ip access-group systems.XXXX_acl in
no ip route-cache
bridge-group 5
bridge-group 5 subscriber-loop-control
bridge-group 5 block-unknown-source
no bridge-group 5 source-learning
no bridge-group 5 unicast-flooding
bridge-group 5 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid XXXXXXXXXXXXXX
ssid systems.XXXX
ssid systems.XXXX
antenna gain 0
dfs band 1 2 block
speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
power local 8
power client 8
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.993
ip access-group fhbhotspot_acl in
no ip route-cache
bridge-group 7
interface Dot11Radio1.1200
description systems.XXXXX
no ip route-cache
bridge-group 2
interface Dot11Radio1.1210
no ip route-cache
bridge-group 3
interface Dot11Radio1.1220
no ip route-cache
bridge-group 4
interface Dot11Radio1.1230
ip access-group systems.msc_acl in
no ip route-cache
no keepalive
bridge-group 5
interface GigabitEthernet0
no ip address
no ip route-cache
duplex full
speed 100
no keepalive
bridge-group 1
interface GigabitEthernet0.993
ip address 172.20.100.6 255.255.255.0
no ip route-cache
bridge-group 7
interface GigabitEthernet0.1200
ip address 172.20.200.6 255.255.255.0
no ip route-cache
bridge-group 2
interface GigabitEthernet0.1210
ip address 172.20.210.6 255.255.255.0
no ip route-cache
bridge-group 3
interface GigabitEthernet0.1220
ip address 172.20.220.6 255.255.255.0
no ip route-cache
bridge-group 4
interface GigabitEthernet0.1230
ip address 172.20.230.6 255.255.255.0
no ip route-cache
bridge-group 5
interface GigabitEthernet0.1255
encapsulation dot1Q 1255
ip address 172.20.255.6 255.255.255.0
no ip route-cache
bridge-group 6
no bridge-group 6 source-learning
bridge-group 6 spanning-disabled
interface BVI1
ip address 172.20.200.5 255.255.255.0
no ip route-cache
ip default-gateway 172.20.200.1
no ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip access-list extended fXXXXXXXXXXXXt_acl
permit tcp 0.0.0.0 255.255.255.0 host 192.168.4.20 eq 443
permit udp any eq bootpc host 255.255.255.255 eq bootps
permit icmp 172.20.100.0 0.0.0.255 host 172.20.100.1 echo
permit tcp 172.20.100.0 0.0.0.255 host 192.168.4.17 eq 443
permit tcp 172.20.100.0 0.0.0.255 host 192.168.4.20 eq 443
permit tcp 172.20.100.0 0.0.0.255 host 192.168.5.10 eq domain
permit tcp 172.20.100.0 0.0.0.255 host 192.168.5.11 eq domain
permit udp 172.20.100.0 0.0.0.255 host 192.168.5.10 eq domain
permit udp 172.20.100.0 0.0.0.255 host 192.168.5.11 eq domain
deny   ip 172.20.100.0 0.0.0.255 10.0.0.0 0.255.255.255
deny   ip 172.20.100.0 0.0.0.255 172.16.0.0 0.15.255.255
deny   ip 172.20.100.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 172.20.100.0 0.0.0.255 any
ip access-list extended systemsXXXXX_acl
permit udp 172.20.230.0 0.0.0.255 eq bootpc host 192.168.5.11 eq bootps
permit icmp 172.20.230.0 0.0.0.255 host 172.20.230.1 echo
permit icmp 172.20.230.0 0.0.0.255 host 192.168.5.10 echo
permit icmp 172.20.230.0 0.0.0.255 host 192.168.5.11 echo
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq domain
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq domain
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq domain
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq domain
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 88
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 88
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 88
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 88
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq ntp
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq ntp
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 135
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq netbios-ns
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq netbios-ns
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq netbios-dgm
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq netbios-dgm
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 139
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 139
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 389
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 389
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 389
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 389
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 445
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 445
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 445
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 445
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 464
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 464
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 464
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 464
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 636
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 636
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 3268
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 3268
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 3269
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 3269
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 6201
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 6201
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 6202
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 6202
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 6203
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 6203
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 6204
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 6204
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.10 eq 9389
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.11 eq 9389
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.17 eq 8080
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.27 eq www
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.15 eq 445
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.16 eq 445
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.150 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.151 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.152 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.153 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.154 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.155 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.156 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.157 eq 135
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.150 eq 443
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.151 eq 443
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.152 eq 443
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.153 eq 443
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.154 eq 443
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.155 eq 443
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.156 eq 443
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.157 eq 443
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.150 eq 60001 60002 60003
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.151 eq 60001 60002 60003
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.152 eq 60001 60002 60003
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.153 eq 60001 60002 60003
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.154 eq 60001 60002 60003
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.155 eq 60001 60002 60003
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.156 eq 60001 60002 60003
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.157 eq 60001 60002 60003
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.25 eq 135
permit udp 172.20.230.0 0.0.0.255 host 192.168.5.25 eq snmp
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.25 eq 445
permit tcp 172.20.230.0 0.0.0.255 host 192.168.5.25 eq 9100
deny   ip 172.20.230.0 0.0.0.255 10.0.0.0 0.255.255.255
deny   ip 172.20.230.0 0.0.0.255 172.16.0.0 0.15.255.255
deny   ip 172.20.230.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 172.20.230.0 0.0.0.255 any
snmp-server community XXXXX RO
snmp-server location XXXXXX
snmp-server contact XXXXX
snmp-server chassis-id XXXXX
radius-server attribute 32 include-in-access-req
bridge 1 route ip
line con 0
line vty 0 4
transport input ssh
sntp server 192.168.5.10
sntp broadcast client
end
Markus
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
VIP Purple
Create an additional sub-interface for management & put it into bridge group 1 (which needs to be on native vlan) like below. Assuming 172.20.200.x is on vlan 200 (if not replace 200 in below config with correct vlan number belongs to that subnet)
On the AP do the following
int d0.200
en do 200 native
bridge-group 1
int g0.200
en do 200 native
bridge-group 1
On the switch port where you connected this AP make sure vlan 200 would be the native
interface gx/x
sw tr na vl 200
That should give you the reachability to your AP management IP which is configured under BVI.
Rasika
The management interface of the autonomous APs can only be on the native VLAN.
If you don't have a native VLAN then the management of the AP is not possible through the network.
Rating useful replies is more useful than saying "Thank you"
Hall of Fame Super Gold
Wrong forum, post in "Wireless". You can move your posting with the Actions panel on the right.
Hello Mark,
You must use the default VLAN for management.
The BVI interface must belong to the default VLAN. Otherwise it will not work.
Assign one of the VLANs to be the native:
encapsulation dot1Q native
apply the above command to the sub-interface that represents the default VLAN in all interfaces (d0, d1 and Fa0).
Amjad
VIP Purple
int d0.200
en do 200 native
bridge-group 1
int g0.200
en do 200 native
bridge-group 1
interface gx/x
sw tr na vl 200
Rasika
Re: Aironet 1140G Gateway issues
Hi @ all,
the aironet has a connection to the switch, on the trunkung is vlan 1 as native configured.
in our company must the native vlan as unused.
ok thank you, i will check it ....
352
