Aironet 350 does NOTHING
Cannot even connect via hyperterminal with required settings. Plugging in with ethernet doesn't do anything either except I get a blinking light on the switch. Never any light on the device.
Re: Aironet 350 does NOTHING
Are you connecting the power injector correctly ? If so maybe it's DOA.
Hall of Fame Super Silver
If you are not getting any lights on the AP... looks like bad porwer injector, bad port if you are using a power switch, or just a bad AP. Try to use a different power injector and cat5e cable.
-Scott
135
