Airsnort security audit and cisco kit
Hi all,
I am soon to undertake a security review of our 802.11b network which uses a mix of Aironet 350 and 1200 APs and 350 pcmcia cards.
I have read conflicting reports regarding which cards can be used with which programs... I would ideally like to use Airsnort on Redhat - my question is will Aironet 350 client cards work with Airsnort? I believe the program requires the card to support passive RF monitoring? Any help/comments appreciated.
  • Security and Network Management
1 REPLY
Re: Airsnort security audit and cisco kit
For details on Airsnort you are best to go to the source.
http://airsnort.shmoo.com/
These guys have lots of information. Cisco does not support airsnort, so you will need to contact them if you have problems with this.
From the airsnort website though you will see they have tested using our Client adapaters so it should work well.
271
