AP 1130AG with dot1x and EAP-TLS with ACS
Folks,
I?m using the follow url to config dot1x with EAP-TLS and ACS authentication:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00801df0ea.shtml#config-ap
I have some problems to config EAP-TLS ( dot1x ) in my AP because the document screen are different of my AP.
Does anybody has a cli config or another doc to show me?
Tks
1 REPLY
Re: AP 1130AG with dot1x and EAP-TLS with ACS
aaa group server radius rad_eap1
server 10.1.2.9 auth-port 1812 acct-port 1813
server 10.1.2.10 auth-port 1812 acct-port 1813
aaa authentication login eap_methods1 group rad_eap1
dot11 vlan-name healthy vlan 555
dot11 ssid VSW
vlan 555
authentication open eap eap_methods1
mobility network-id 555
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 556 key 1 size 128bit xxx transmit-key
encryption vlan 556 mode ciphers wep128
encryption vlan 555 key 1 size 128bit xxx transmit-key
encryption vlan 555 mode ciphers wep128
ssid VSW
radius-server host 10.1.2.9 auth-port 1812 acct-port 1813 timeout 6 retransmit 3 key 7 02110D5D02
radius-server host 10.1.2.10 auth-port 1812 acct-port 1813 timeout 6 retransmit 3 key 7 02110D5D02
In this config I use WEP encryption with Open Eap authentication, client authenticates by ACS server, and only there you must configure the type of authentication (TLS, MSCHAP, FAST), on access point you can't configure the type of authentication, you must use only this command "authentication open eap eap_methods"
425
