rri
AP 1200 upgrade via tftp problem ...
I tired to upgrade my APs via tftp from 12.2(8)JA to 12.2(11)JA1. This seems only to work if the tftp server is on the same subnet as the APs (no vlans configured). If I tried to use a tftp server on a different subnet I could not see a single tftp packet from that accesspoint ( I sniffed with tcpdump ). Ping and telnet to the tftp server worked and
I used this comand:
archive download-sw /overwrite /reload tftp:[[//location]/directory]/image-name
Did I miss anything ?
Ruedi
1 REPLY
rri
Re: AP 1200 upgrade via tftp problem ...
OK, wrong syntax I used ...
it has to look like
archive download-sw /overwrite /reload tftp://1.1.1.1//tmp/image
Its got to be a // both times ....
Ruedi
186
