AP being contained by own access points
We've recently installed 802.11ac Wave 1 modules in our 3600 series APs. On 3 (of12) we're seeing containment messages indicating that the ap is being contained (see below) this appears to resolve itself after a couple of minutes, it's always the 3 below but not always at the same time, ap35 and ap36 are near each other.
1. Message: AP 'ap36' is being contained. This is due to rogue device spoofing or targeting AP 'ap36' BSSID on '802.11a' radio.
2. Message: AP 'ap48' is being contained. This is due to rogue device spoofing or targeting AP 'ap48' BSSID on '802.11a' radio.
1. Message: AP 'ap35' is being contained. This is due to rogue device spoofing or targeting AP 'ap35' BSSID on '802.11a' radio.
We're running 7.6.120.0 on the controllers, not sure how to resolve this, it show's the APs MAC address as being spoofed.
Any ideas?
Ben
1 ACCEPTED SOLUTION
You're almost certainly
You're almost certainly hitting:
https://tools.cisco.com/bugsearch/bug/CSCuo60383
Symptom:
The 3602 may try to contain its own radio interface if it has an RM3000AC module is install. You will see messages on Prime infrastructure about this containment. It does not appear to cause any connectivity issues other than the message.
Conditions:
Ap3602 with an RM3000AC module installed
Workaround:
None
Known Affected Releases:
(2)
7.6(121.0)
7.6(100.22)
Known Fixed Releases:
(3)
8.0(72.235)
8.0(72.236)
7.6(122.16)
Hopefully 7.6MR3 isn't too far away...
VIP Purple
Hi,Looks like that Some other
Looks like that Some other AP is using the BSSID of your AP and sending deauth.
1. If you have multiple Controllers , Make sure all are configured with the same RF group.
2. Find out the system containing this access point. might need to use a wireless sniffer/trace.
Hi.We have 3 controllers all
Hi.
We have 3 controllers all in the same group, it only seems to have happened since installing the AC wave 1 modules. We'll do some further troubleshooting, I doubt we have an another ap trying to contain ours.
Ben
Symptom:
Conditions:
Workaround:
None
(2)
7.6(121.0)
7.6(100.22)
(3)
8.0(72.235)
8.0(72.236)
7.6(122.16)
Hi,This was supposed to be
This was supposed to be fixed but is still occurring, new bug CSCur22714, how do we get a hold of 7.6.130.19? The alerts are quite annoying...
Ben
Hi,I suspect this to be some
I suspect this to be some kind of bug, the AP is detecting the other radio but it shouldn't. With a Wave 1 module installed it uses the same MAC address for both a/n/ac radios and I suspect this is the issue, this shows up in Prime and on the controller. Will have to get a TAC case opened.
Ben
Gold
http://www.google.co.in/url
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0CCwQFjAC&url=http%3A%2F%2Fwww.cisco.com%2Fc%2Fdam%2Fen%2Fus%2Ftd%2Fdocs%2Fwireless%2Fprime_infrastructure%2F1-3%2Fconfiguration%2Fguide%2FCPI_Alarms_Events.xls&ei=9g...
AP_CONTAINED_AS_ROGUEbsnAPContainedAsARogueAP contained as rogueAP_CONTAINED_AS_ROGUE_YES: AP ''{bsnAPIdentifier}'' is being contained. This is due to rogue device spoofing or targeting AP ''{ bsnAPIdentifier }'' BSSID on ''{ radioType }'' radio.
AP_CONTAINED_AS_ROGUE_NO: AP ''{ bsnAPIdentifier }'' with protocol ''{radioType}'' on Controller ''{senderIP}'' is no longer being contained. Service is restored.
An access point is reporting that it is being contained as a rogueCriticalRogue APAnother system is containing this access point. Identify the system containing this access point. You might need to use a wireless sniffer.WCS 2.0
760
