AP GUI Authentication
I would like to know how to change the default username and password for some Cisco AP's that I have.
I know I can do it through the CLI and GUI. But, this is my question. When I do so through the GUI, I am
able to telnet into the AP with the username and password I create. When I go to the GUI, the access level
is 1. Is there something I'm doing wrong that makes it access level 1 instead of 15?
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
There is a difference, but if you can edit the settings from the GUI then you are good.  Now try to create a user with privilege of 1 and telnet or try to gui and see if its the same.
-Scott
Trying entering:
username privilege 15 password
-Scott
yes, I've done that in the CLI as well. When I go back to the GUI, it will still take the default credentials.
I did the whole username line you advised.
I can see it in the running config and it works no matter what
settings I put via the GUI. When I go to the Admin Access
portion of the GUI, I select local user list only option for authentication.
I created a read-write user account, equal to the credentials in the CLI.
But for some reason the access level goes to 1.
Re: AP GUI Authentication
Have you tried to enabel secure http server so you can https to the AP?
ip http secure-server
-Scott
Here is a doc for configuring ssh:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f029f.shtml
-Scott
I went ahead and enabled the http secure-server and still had the level 1 access.
Does it really matter the difference in levels 1 or 15? I go into the GUI and am
able to edit the settings. I just don't understand why it's level 1 instead of 15.
-Scott
The level_1 account goes in, but when I try to edit anything through the GUI it asks me for the Level_15 username and password. So I'm thinking putting in the level 15 UN and Pass overrides the level 1 prompt.
Yup... So there you go:)
For best practice you should disable telnet and http and use ssh and https.
Sent from my iPhone
-Scott
373
