AP's not authenticating
On my wireless network no one can suddenly connect i have looked in the log's on one of the ap's and have found this message.
%LEAPCL-3-FAILED: AP Authentication to the WDS failed
I have done a debug on the authentication state on the WDS output below:
*Mar 8 02:32:19.368: wlccp_ap_fsm: START-FSM: event:wlccp_ap_ev_timeout, state: wlccp_ap_st_init
*Mar 8 02:32:19.368: wlccp_ap_fsm: start AP leap authentication
*Mar 8 02:32:19.368: wlccp_ap_fsm: END-FSM:state:wlccp_ap_st_init -> state: wlccp_ap_st_leap_auth
*Mar 8 02:32:19.374: wlccp_ap_fsm: leap_auth_resp status failed
*Mar 8 02:32:19.374: wlccp_ap_fsm: START-FSM: event:wlccp_ap_ev_leap_reply, state: wlccp_ap_st_leap_auth
*Mar 8 02:32:19.374: wlccp_ap_fsm: retry leap authentication later...
Would resetting the wlcpp password on the WDS and the AP's resolve this?
Kev
1 REPLY
Silver
Re: AP's not authenticating
If you are running a WLC or WiSM, (i.e.: Lightweight) you may want to check to make sure that the security hashes are still in your controller.
Typically, these are created on your controller once you have migrated to LWAP.
844
