Community Member
AP with EAP and managment control through ACS
I have deployed a number of wireless networks with EAP authenticated through the users domain account details passed to ACS 4.1. This appears to work fine, but I have two questions regarding control of access.
1. I have configured RADIUS for the EAP and then added TACACS+ for the management access of the AP. Although going back to the same ACS server with different protocols I am unable to get the managment access control to work if both are active? Should this work?
2. How do I control which VLAN / SSID a user has access to? it seems as though there is no way to limit them to a specific SSID (other than not telling them it) If the users have a guess at the SSID then the possibility is that they can access a LAN they should not.
Any help would be very greatfully received.
1 REPLY
Community Member
Re: AP with EAP and managment control through ACS
Hi ihill,
in answer to your second question there is a couple of ways that you can do this depending on the amount of control you have over your clients.
You could use dynamic VLAN assignment:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml
You could use Active Directory wirelss group policy to define prefered wirless networks for your clients
Or you could use a 3rd party supplicant like the Juniper Network's Odyssey Access Client
http://www.juniper.net/products_and_services/aaa_and_802_1x/odyssey/odyssey_access_client/
hope this helps
Mark
*pls rate all useful posts
141
