AP3602E not join with remote 5508
Hi Team
We have a wlc 5508 in central site. versión 7.6.100
A remote AP 3602E located in remote site. version 12.4.(25e) JAL1a
The AP can´t join and register to WLC.
We can check the AP is seen in WLC in the following Window screen in Monitor > statistics > ap joint and is marked like not joined.
Please check the errormsg.txt file attached : check the request for join and discard from the controller.
I attached several aditional files sh sysinfo and sh version from wlc an WAP
What can we do?
any help is necessary
Regards.
Hall of Fame Super Silver
Re: AP3602E not join with remote 5508
Do you have access to the AP?  If so, console into the ap and issue:
capwap ap controller ip address
If not, create an ip helper on the subnet the AP is on
ip helper-address
Then globally on the router
ip forward-protocol udp 12222
ip forward-protocol udp 12223
ip forward-protocol udp 5246
ip forward-protocol udp 5247
Output from the console of the AP would really help and make sure the time on the WLC is correct.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Hi Scott,
This is the output from the console of the AP
*Jan 24 14:34:42.803: %CAPWAP-3-EVENTLOG: spamResolveStaticGateway - Removing default route for existing gateway 0.0.0.0
*Jan 24 14:34:42.803: %CAPWAP-3-EVENTLOG: spamResolveStaticGateway - Adding default route for gateway 10.180.41.1
*Jan 24 14:34:42.803: %CAPWAP-3-EVENTLOG: spamResolveStaticGateway  - gateway found 10.180.41.1
*Jan 24 14:34:52.803: %CAPWAP-3-EVENTLOG: Could not discover any MWAR.
*Jan 24 14:34:52.803: %CAPWAP-3-EVENTLOG: Starting Discovery. Initializing discovery latency in discovery responses.
*Jan 24 14:34:52.803: %CAPWAP-3-EVENTLOG: CAPWAP State: Discovery.
My name is Alberto and I am sertorivs coworker.
Best regards.
Can you post the output from when you reboot the AP and let it run for a while. What you have doesn't say much.
-Scott
Hi Scott,
The time is correct and is synchronized with an NTP server.
I have also added the commands and status but is not joined
Post the full output.
-Scott
Hi Scott,
This is the output when reboot the AP.
Thanks.
Clear the ap!
debug capwap console cli
erase /all nvram:
[confirm]
undebug all
reload
[confirm]
Scott
-Scott
Hi Scott,
The result is the same, the status is not joined and the output is the same. This is the output of the WLC
*spamApTask0: Jan 29 23:13:40.252: c0:67:af:28:d2:64 Received LWAPP DISCOVERY REQUEST to e4:c7:22:ab:28:80 on port '2'
*spamApTask0: Jan 29 23:13:40.252: c0:67:af:28:d2:64 Discarding discovery request in LWAPP from AP supporting CAPWAP
Thanks.
You have v7.2 on the WLC?
-Scott
The version of wlc is 7.4.110.0
Capture the output again and also run the command I just posted previously and reload without saving.  Also place the ap in the same subnet as the wlc management.
Scott
-Scott
Is not possible that the AP is on the same subnet as the WLC. The AP is in a remote office and the WLC at the central office, communicating via an MPLS.
Okay... well run the commands as I would like to see that in the output and then after the AP gets a valid ip address, issue the following
Scott
-Scott
This is the output of AP
Don't run the debug.... how many AP's do you have there that is joined to the WLC?
Scott
-Scott
What debug not want me to run?
There are no AP joined in the WLC, this is a new installation.
Don't run this...debug capwap client event  I want to see the AP try to find and show a fail and reboot again.
Since this is a new install, then maybe you have something blocking UDP 5246 and UDP 5247.  I though there were other APs up and you only had issue with this one.  The only other way to see if something is blocking is to ship the AP back and connect it on the same subnet as the WLC.  If that joins fine, then send it back to the remote site.  If the AP doesn't join, then something is blocking or dropping those two ports.
Scott
-Scott
I have another AP and the output is the same, do not think it's a hardware problem in AP.
Thanks.
It's not a hardware problem... there is something blocking the upd ports for the join.
Scott
-Scott
You need to also let the log runs... there is more info that needs to be shown... let it go for like 5 minutes or so.
Scott
-Scott
Debug any specific or just the connection to the console.
Thanks.
No debug... just capture the output from the console, reboot the AP and let that run for 5+ minutes.
-Scott
This debug is of 10 minutes.
And this debug is the switch where is connected the ap
C2960X#
Jan 29 23:46:06.690: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:46:16.690: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:46:26.687: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:46:36.688: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:46:36.691: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:46:46.024: UDP: rcvd src=10.180.0.17(123), dst=10.180.41.2(123), length=56
Jan 29 23:46:46.688: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:46:56.689: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:47:06.686: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:47:06.689: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:47:16.686: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:47:16.690: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:47:26.687: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:47:36.683: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:47:36.687: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:47:46.684: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:47:46.687: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:47:51.029: UDP: rcvd src=10.180.0.17(123), dst=10.180.41.2(123), length=56
Jan 29 23:47:56.684: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:48:06.685: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:48:16.685: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:48:26.686: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:48:36.683: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:48:46.683: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:48:56.040: UDP: rcvd src=10.180.0.17(123), dst=10.180.41.2(123), length=56
Jan 29 23:48:56.684: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:49:06.684: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:49:16.684: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:49:26.685: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:49:36.685: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:49:46.686: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:49:56.686: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:49:59.035: UDP: rcvd src=10.180.0.17(123), dst=10.180.41.2(123),
Jan 29 23:50:06.687: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:50:16.687: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:50:26.687: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:50:36.677: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:50:46.678: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:50:56.678: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:51:04.047: UDP: rcvd src=10.180.0.17(123), dst=10.180.41.2(123), length=56
Jan 29 23:51:06.675: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:51:06.679: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:51:16.675: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:51:26.676: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:51:26.679: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:51:36.676: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:51:46.677: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:51:56.674: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:52:06.674: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:52:07.041: UDP: rcvd src=10.180.0.17(123), dst=10.180.41.2(123), length=56
Jan 29 23:52:16.674: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:52:26.671: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:52:26.675: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:52:36.672: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:52:46.672: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:52:56.673: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:53:06.670: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:53:06.673: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:53:11.053: UDP: rcvd src=10.180.0.17(123), dst=10.180.41.2(123), length=56
Jan 29 23:53:16.670: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:53:26.671: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:53:26.674: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:53:36.671: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:53:46.671: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:53:56.668: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:54:06.669: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:54:16.669: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Jan 29 23:54:18.057: UDP: rcvd src=10.180.0.17(123), dst=10.180.41.2(123), length=56
Jan 29 23:54:26.670: UDP: rcvd src=10.180.41.21(36135), dst=255.255.255.255(5246), length=131
Jan 29 23:54:36.667: UDP: rcvd src=10.180.41.21(36134), dst=255.255.255.255(12223), length=98
Thanks.
That output didn't have much... oh well...
How many AP's do you have up on your WLC?  From this site to the site the WLC is at, you are not using NAT are you?
Scott
-Scott
VIP Purple
HI,
As per yor Logs:
*spamApTask0: Jan 29 18:47:03.491: c0:67:af:28:d2:64 Received LWAPP DISCOVERY REQUEST to e4:c7:22:ab:28:80 on port '2'
*spamApTask0: Jan 29 18:47:03.491: c0:67:af:28:d2:64 Discarding discovery request in LWAPP from AP supporting CAPWAP
you are using..Layer 2 LWAPP WLC Discovery Algorithm
Your Management IP(10.180.5.3) and AP IP(10.180.41.16) is in diffirent subnet
Try to use AP and WLC in same subnet and then try again.
Reagrds
Hi sandeepchoudhary21,
We are using Layer 3 LWAPP WLC Discovery Algorithm with option 43 in the DHCP that I have mounted swtich where the AP is connected
Thanks.
VIP Purple
Can you ping the AP from WLC ???
Also paste the output of these commands:
debug capwap event enable or debug lwapp event enable or
debug pm pki enable
VIP Purple
First of all make sure your AP can reach 5508 management IP. Go to AP console (once it obtained IP via DHCP) & then ping WLC mgt IP address.
*Jan 24 11:45:07.211: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C2960X-24PS-L (c414.3cad.e801)
*Jan 24 11:45:21.771: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.180.41.20, mask 255.255.255.0, hostname APc067.af28.d264
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (10.180.32.19) (10.180.32.17) [OK]
*Jan 24 11:45:32.655: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.180.5.3 obtained through DHCP
*Jan 24 11:45:32.655: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
Through your log msg we can see 10.180.5.3 is the WLC IP learn by AP via DHCP option 43. Is it the one you configured on your 5508 ? (show interface summary output of your WLC will prove this)
Also you have PoE issue where all radio get disabled due to low power available via your 2960. That to be fixed as well
Rasika
**** Pls rate all useful responses ****
I can ping from the AP to the WLC and the WLC from AP.
(Cisco Controller) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Gu        est
management                       2    untagged 10.180.5.3      Static  Yes    No
service-port                     N/A  N/A      10.180.2.5      Static  No     No
virtual                          N/A  N/A      1.1.1.1         Static  No     No
446
