Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Ap521 - 802.1x LEAP - with IAS ?
Hi there,
I wanted to do 802.1x PEAP with my AP521 in standalone access-point. unfortunetely.. in the data sheet it seems to support only LEAP with AP521.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7306/ps7319/ps7338/product_data_sheet0900aecd8060c220.html
LEAP
Dynamic-WEP
Open-EAP Network-EAP
So,  as I have Microsoft IAS, I was trying to figure out if LEAP is supported ... it seems that officialy not :
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_q_and_a_item09186a00805e8297.shtml
and from microsoft also
http://technet.microsoft.com/en-us/library/cc785368(WS.10).aspx
But, some people on forum said there is some things you can do to make it work...
https://supportforums.cisco.com/message/1295984#1295984
By default, the access point sends reauthentication requests to the authentication server with the service-type attribute set to authenticate-only. However, some Microsoft IAS servers do not support the authenticate-only service-type attribute. Changing the service-type attribute to login-only ensures that Microsoft IAS servers recognize reauthentication requests from the access point. Use the dot11 aaa authentication attributes service-type login-only global configuration command to set the service-type attribute in reauthentication requests to login-only.
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_guide_chapter09186a00802091b1.html
What Do you Think ?? did you guys done that ?
thanks
1 REPLY
Re: Ap521 - 802.1x LEAP - with IAS ?
Phillippe,
     PEAP is supported through the APs which is most likely what you will use in a Microsoft environment.  This is covered under the Open-EAP heading.
--Jesse
627
