Community Member
Are there any wireless controler that will accept Downloadable Access-list ?
Currently any vpn user apon connection the network has an ACL pushed from ACS to ASA.
I want to do the same for wireless but I dont use the ASA. Will one of the wireless controllers accept Downloadable ACL's like the ASA ?
Michael
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Are there any wireless controler that will accept Downloadab
NO.  Because the ACL syntax on the WLC are different.
Gold
You can create an ACL on the controller and have the Radius server apply that ACL to specifiec users .
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60sol.html#wp1086421
Community Member
Dan,
That would be tricky at best. If its per user would mean 10,000 ACL at about 200 lines each.  hmmm that won't fit on a 4402 now will it ?
I'm using RSA authentication, If I can do it like I do with the ACS/RSA on a per group basis would drop to about 144 ACLs at about 200 lines.
Correct me if I'm wrong but I can't use the ASA with DACL unless I'm using IpSec.
At this point I'm not limiting myself to the Wireless controllers I thought it would be the simplest solution.
452
