Arp issue on Cisco 891w
Hi Guys,
I have a 891w wifi router which is configured as non-root bridge universal and it is connected to my netgear wireless router.
Ping from 891w works but from others to 891w does not.
Mac-book --ping--> Router vlan 1 or bvi 1 does not work
891w---ping---> Mac-book works
Then Mac-book --ping--> Router vlan 1 or bvi 1 Works
So when i'm adding Router's mac address to MAC-book arp table it works but when i remove the arp it doesn't work and it won't learn it.
Please advise.
Config:
Wireless#sh run
Building configuration...
Current configuration : 5616 bytes
version 12.4
service password-encryption
hostname Wireless
boot-start-marker
boot system flash c890-universalk9-mz.124-22.YB8.bin
boot config usbflash0:CVO-BOOT.CFG
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
enable secret 5
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
crypto pki trustpoint TP-self-signed-933468444
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-933468444
revocation-check none
rsakeypair TP-self-signed-933468444
crypto pki certificate chain TP-self-signed-933468444
certificate self-signed 01
  30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 39333334 36383434 34301E17 0D313331 31313930 37353932
  315A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3933 33343638
  34343430 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  9ED60258 E8646429 3588B7F9 9E62313F EE559088 10B4DBED CDB3042A CA5DF8D8
  7347B1B3 2B5BDEBF 78A59C2E 6C5CC32B 5E84D918 2E82998A 28CB6A1E BFC1610D
  EF755A91 82EA65A8 EC92D223 F8446D14 5D4650FD 30EEC02A 951B4CDA 36850F03
  16839D47 D5D9A09C C2FB004B 6D9FD4C0 EB22F863 DCFFE059 77A93D9C 4B37F78F
  02030100 01A36D30 6B300F06 03551D13 0101FF04 05300301 01FF3018 0603551D
  11041130 0F820D57 6972656C 6573732E 43434945 301F0603 551D2304 18301680
  14809BA7 4897A531 4B9B4208 59B11681 27CAB8EB C7301D06 03551D0E 04160414
  809BA748 97A5314B 9B420859 B1168127 CAB8EBC7 300D0609 2A864886 F70D0101
  04050003 8181007D 79499AFF 6EB67BB9 EB610083 66F21A9B 7B8098A4 B5AE092A
  6FE23F26 0B3456BF CADF2C3D 1C9422D8 4BCD422F B17641FC 00514E85 9C9A8237
  ED1C69A0 12A36294 F62C801B 27B5FEEC 23F6D667 1A93A5CD 040F3A65 357F7468
  EFB82B61 9F8CE2A2 86926853 F1B3F095 F8825BDD 75333F4B 9BE74C64 CCFA00C6
  A7BAC332 96E91E
      quit
ip source-route
ip cef
no ip domain lookup
ip domain name CCIE
no ipv6 cef
username admin privilege 15 secret 5 xx
archive
log config
  hidekeys
zone security inzone
bridge irb
interface FastEthernet0
switchport access vlan 2
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
no ip address
duplex auto
speed auto
interface GigabitEthernet0
description $ES_WAN$$FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
shutdown
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip address 1.1.1.2 255.255.255.252
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
zone-member security inzone
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
no ip address
ip access-group 100 in
ip access-group 100 out
ip tcp adjust-mss 1460
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
interface Vlan2
ip address 10.10.10.1 255.255.255.0
interface Async1
no ip address
encapsulation slip
interface BVI1
ip address 192.168.1.150 255.255.255.0
ip helper-address 192.168.1.1
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip sla auto discovery
ip sla 1
icmp-echo 4.2.2.4 source-ip 192.168.1.150
verify-data
frequency 15
ip sla schedule 1 start-time now
access-list 100 permit ip any any
access-list 100 permit icmp any any
no cdp run
arp 192.168.1.1 204e.7fa3.6eac ARPA
arp 192.168.1.200 0092.5800.6db0 ARPA
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner exec ^C
% Password expiration warning.
Cisco Virtual Office (CVO) is installed on this device and it provides the
default username "cisco".
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin udptn ssh
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler max-task-time 5000
end
1 REPLY
Hall of Fame Super Gold
Duplicate posts.
Go here.
189
