ASA 5510+ASA SSM-10
hi,
Any one help me out i have to configre IPs on ASA 5510.
where i will put this IPS(inside,outside or DMZ)
Gigabit port of ASA SSM 10 module will be used or not
plz help
and inform me from basics
1 REPLY
Re: ASA 5510+ASA SSM-10
Hello Asim
Have a look at this:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807335ca.shtml
The Gigabit port is for management only, the traffic is diverted using the 'internal connection' shared between the ASA backplane and the AIP-SSM module.
Please note there are dedicated forums for Security >> Firewalling and Security >> IPS, where you will get quicker responses :)
Hope this helps,
Farrukh
140
