ASA crashed!!!!!
can someone help please!!!  My ASA 5510 just stopped working. It will not connect to the Internet. I could ping the DNS and the interfaces but could not get to the Internet. When I connect my Laptop to the ISP router it works finehere is the configuration
: Saved
ASA Version 8.0(3)
hostname ******
domain-name ********
enable password m/TMGLxcraOUG46C encrypted
names
name 10.0.10.4 Server description Exchange Server
interface Ethernet0/0
nameif Inside
security-level 100
ip address 10.0.10.253 255.255.255.0
interface Ethernet0/1
nameif Guest
security-level 50
ip address 10.0.2.254 255.255.255.0
interface Ethernet0/2
nameif Outside
security-level 0
ip address 87.85.201.99 255.255.255.248
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name ktcoils.local
access-list Inside_nat0_outbound extended permit ip any 10.0.10.172 255.255.255.252
access-list Outside_access_in extended permit tcp any host SBSServer eq smtp log
access-list Inside_access_in extended permit tcp host SBSServer any eq smtp log
pager lines 24
logging enable
logging asdm informational
mtu management 1500
mtu Guest 1500
mtu Outside 1500
mtu Inside 1500
ip local pool VPNPool 10.0.10.180-10.0.10.189 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-508.old
no asdm history enable
arp timeout 14400
global (Outside) 2 87.85.201.100-87.85.201.105 netmask 255.0.0.0
global (Outside) 1 interface
global (Inside) 1 interface
nat (Guest) 1 0.0.0.0 0.0.0.0
nat (Outside) 1 10.0.10.172 255.255.255.252 outside
nat (Inside) 0 access-list Inside_nat0_outbound
nat (Inside) 2 0.0.0.0 0.0.0.0
static (Inside,Outside) 87.85.201.106 SBSServer netmask 255.255.255.255
access-group Outside_access_in in interface Outside
access-group Inside_access_in in interface Inside
route Outside 0.0.0.0 0.0.0.0 87.85.201.97 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
group-policy KTCRemote internal
group-policy KTCRemote attributes
wins-server value 10.0.0.4
dns-server value 212.135.1.36
vpn-tunnel-protocol IPSec
default-domain value ktcoils.local
username admin password czGCDdLJBAwTP.41 encrypted privilege 15
username user1 password enq05bKrudsJMMBu encrypted
username user1 attributes
vpn-group-policy KTCRemote
username user2 password enq05bKrudsJMMBu encrypted
username Interactive password 8XYOLdGxohhVdJTN encrypted
tunnel-group KTCRemote type remote-access
tunnel-group KTCRemote general-attributes
address-pool VPNUsers
default-group-policy KTCRemote
tunnel-group KTCRemote ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:ab59b47ce5b9aa70d38cc9d1abfaf2c8
: end
asdm location Server 255.255.255.255 Inside
1 REPLY
Re: ASA crashed!!!!!
Good day,
Since this has to do with ASA, please open a new one under Firewalling and close this one?
This community is for Wireless Discussions.
Serge
223
