ASA5550 VPN premium licence
I have a client with an ASA5550 that has the following licenced features. The output below shows that it has the VPN Premium Licence, can it be confirmed if this is a standard feature of the ASA5550 or is it a licence that needs to be purchased. The client needs to buy a replacement device which I can get hold of as a Cisco refurb unit, but I want to ensure it is licenced with any additional licences correctly.
Cisco Adaptive Security Appliance Software Version 7.1(2)
Device Manager Version 5.1(2)
Compiled on Tue 14-Mar-06 17:00 by dalecki
System image file is "disk0:/asa712-k8.bin"
Config file at boot was "startup-config"
fw up 34 days 5 hours
Hardware: ASA5550, 3968 MB RAM, CPU Pentium 4 3000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0 : address is 001b.d588.9e6a, irq 9
1: Ext: GigabitEthernet0/1 : address is 001b.d588.9e6b, irq 9
2: Ext: GigabitEthernet0/2 : address is 001b.d588.9e6c, irq 9
3: Ext: GigabitEthernet0/3 : address is 001b.d588.9e6d, irq 9
4: Ext: Management0/0 : address is 001b.d588.9e69, irq 11
5: Int: Internal-Data0/0 : address is 0000.0001.0002, irq 11
6: Int: Not licensed : irq 5
7: Ext: GigabitEthernet1/0 : address is 001b.d588.9b85, irq 255
8: Ext: GigabitEthernet1/1 : address is 001b.d588.9b86, irq 255
9: Ext: GigabitEthernet1/2 : address is 001b.d588.9b87, irq 255
10: Ext: GigabitEthernet1/3 : address is 001b.d588.9b88, irq 255
11: Int: Internal-Data1/0 : address is 0000.0003.0002, irq 255
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 200
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 5000
WebVPN Peers : 2
This platform has an ASA 5550 VPN Premium license.
Serial Number: JMX1134L0NR
Running Activation Key: 0x6a3d6642 0x6430645a 0x7cb205d8 0x8170b0a4 0x453e80ba
Configuration register is 0x1
Configuration last modified by enable_1 at 11:13:53.299 BST Thu Oct 9 2014
Many thanks
Richard
1 ACCEPTED SOLUTION
Bronze
Hello, Richard. Just to give
Hello, Richard.
Just to give you a heads up, the Cisco ASA 5550 are already been announced as End of Life. You can check this link to see the available features on an ASA 5550 base license: (http://cs.co/9006qBFe).
Are you planning on reselling this to your client, by the way?
Let me know if you have other concerns or need more support. (adawa@cisco.com).
Kind regards.
This sub-board is for
This sub-board is for Wireless security questions, as you are working with an ASA, you'd be better served to move your question to this forum:
https://supportforums.cisco.com/community/6001/vpn
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Bronze
Hello, Richard.
Kind regards.
Brilliant thanks for the
Brilliant thanks for the response.
Fully understand that the 5550 is end of life. The client are budgeting for replacing all of their older ASA units as a major upgrade project. But in the short term they need to replace a existing unit with a refurb unit.
Thanks again for the response.
Rich
241
