Community Member
Autonomous AP to LWAPP
I'm trying to migrate an Autonomous 1131-AP to LWAPP but when i try to prepare the infrastructure to do it pings from AP to WLC (to mngmt interface and to ap-mngmt int) just work for the first minute after the WLC is turning on and after that pings doesn't response. Everything (AP, WLC both interfaces and PC) is on the same subnet 10.0.0.0/24.
Any idea of what's going on??
Hall of Fame Super Silver
Re: Autonomous AP to LWAPP
What model wlc and what code? Something is configured wrong... since it would be the easiest to have everything in one subnet. Are you using the tool to convert or WCS.... need more info.
-Scott
Community Member
Hi, thanks for your response fella5 i really appreciate it, but i already done it, do you wanna know what was it??
First i used a switch to get pings working and after that i typed "aaa new-model" global configuration command in the AP. All this besides the normal procedure.
See u in my next doubt!! =)
136
