beginner: wlc 4402 captive portal
hye all,
i want to ask about captive portal authentication. i have a situation where i used local authentication (on controller) for captive portal. the question is, is it possible we use only single set of username and password for office usage? how many person can use same username and password concurrent?
usually, i used RADIUS SERVER for authentication but somehow not for captive portal. is it possible to use RADIUS SERVER for authentication tied up with captive portal?
  • Security and Network Management
1 ACCEPTED SOLUTION
Re: beginner: wlc 4402 captive portal
Hello !
Yes you can use radius with web authentication. The authentication happens with PAP or CHAP on radius. You can configure a priority order for the portal authentication.
WLAN-> security->aaa servers
There you can prioritize Local db,LDAP and radius.
Yes you can login multiple times with the same username. Check out the WLC web page : Security => User login policies.
Nicolas
Hello !
Nicolas
thank you..
i've solved that matter...
thank you very much..
828
