Blocking SSID selectively in H-REAP mode
We have deployed 500 access-points in 100 sites using 8 controllers.  SSID is switched locally and access-points are in H-REAP mode.
Customer wanted us to host one more SSID, which will be used in only 10 sites. It will be using pre-configured user-name and password for authentication.
1. How to block the SSID from advertising to remaining 90 sites? If I configure any SSID in controller, it is pushed to all 100 sites. How to block SSID selectively.
2. Is there anyway to apply the acl on this SSID in local switching
Ramesh
For the first part you would use the feature called AP Groups.  You would put the AP's for the 10 sites, into their own group(s) that allows the extra SSID.
For the second part, this is possible if you are running 7.2, FlexConnect ACLs.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Thanks Stephen,
AP Groups is applicable to H-REAP APs? Are we allowed to use both H-reap group and AP-group together?. We have H-reap groups for roaming.
we have 4400 series controllers. I see latest version for this is 7.0.230.0. I think 7.2 is not applicable to 4400. not sure.
Hi Stephen,
Correct me if Im wrong.
When you create the this additional SSID, it will be added into the default-group, and there is no way to remove any SSID from this default-group.
Based on this, I think, what it's needed is to create a new group, move "all" APs to this group, create the new SSID, and then only move the APs placed in the 10 sites back to the default-group. This way, APs in the new group carry exisitng SSIDs, and APs in default-group will carry the existing SSIDs and the newly-added SSIDs.
Re: Blocking SSID selectively in H-REAP mode
If you build the WLAN above 17 it will not be on the default group.
Steve
Yes the AP group should still be applicable ti limit which WLAN is at each site.
Ok if you are on a 4402 then you'll have to acl at the local l3 interface as it doesn't support running 7.2
Steve
Ramesh:
I think you asked question 2 as a suggested solution to question 1, right?
So if we resolve question 1 the question 2 can be ignored.
As Steve mentioned, you only add AP groups and that is it.
Here is a config example: http://tiny.cc/j7tqcw
Although config example shows old versoin, it is still be applicable to newer versions (with some few differences). But if you know the concept you'll be able to do it with no problems.
Ask if you got to any issue while configuring this.
Good luck.
Amjad
Rating useful replies is more useful than saying "Thank you"
Re:Blocking SSID selectively in H-REAP mode
good point!
1110
