built in RADIUS - 2504 ?
                   Hi.. still I'm having issue to setup authentication with our external Radius server so I'm thinking whether the 2504 has inbuilt feature which I can configure as a Radius server? if so are there any guide for configuration?
Tks
Everyone's tags (4)
1 REPLY
Re: built in RADIUS - 2504 ?
You can use local EAP feature. It is somehow limited though to the EAP types supported. You can have credentials locally saved or externally (in LDAP Directory)
Check this:
www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080851b42.shtml
Amjad
Rating useful replies is more useful than saying "Thank you"
292
