Bypassing specific traffic on Guest SSID
Hey guys,
I have a guest access setup with WISM and Anchor controllers in DMZ for internet access. L2 security policy is based on WAP2+PSK awith Layer3 on web authentication. Would it be possible to let un-authenticated users to connect to some web sites say Cisco.com (That is without being authenticated by WLC).
Thanks in advance,
Jay
Gold
Re: Bypassing specific traffic on Guest SSID
Sure, that is what the preauthentication ACL is for. Just create an ACL on the WLC and under the WLAN select that ACL for the preauth ACL on the layer-3 security tab. Anything that is permitted by the ACL will be allowed to pass through the controller regardless if the client has authenticated yet or not.
Thx, I will try that. will let you know if face some problems.
Jay
165
